Engine rebuild on SPI ? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-06-2008, 02:02 PM   #11
jeffescortlx
Fan#: 28343
What I Drive: Turbo Escort
FF Reputation: 6 jeffescortlx Good Standing Member
Originally Posted by FocusPilot View Post
There is a shortage of focus spi long blocks because of the valve seat problem
The older CVH's, 1.9's also have the same problem, but it did'nt start showing up as much untill later year's like 96, just so happen when EGR became the norm. But it does seem worse in the Foci for some reason.
and escort owners upgrading to the 2.0.
When the Escort owners swap out there 1.9 for the 2.0, they use the Escort SPI and not the Focus SPI. The Escort SPI is a drop in and go, while the Focus SPI has some differences making it a harder swap. So we cant be blamed for the shortage :P
I guess my point is I'm spoiled, I've bought 2 2.0 SPI's for around $300, a Zetec with low miles for $275 and a SPI head from a U-Pull for $30.
And it might be possible to run a Zetec off the SPI ECU and harness. After all, I made a Zetec run off a 1992 1.9 ECU and harness. Ran pretty damn good to.
1.9 SPI 93 Ford Escort
212whp 262tq <-outdated #'s.
And with stock 1-7/8" Exhaust.
Currently full 3" and e85.
jeffescortlx is offline
Old 11-06-2008, 02:50 PM   #12
FocusPilot
FocusPilot's Avatar
Fan#: 58694
What I Drive: 2003 Silver LX Sedan
Points 340, Level 6
Points: 340, Level: 6 Points: 340, Level: 6 Points: 340, Level: 6
Level Up 80% Completed
FF Reputation: 27 FocusPilot Great Standing Member
Originally Posted by jeffescortlx View Post
When the Escort owners swap out there 1.9 for the 2.0, they use the Escort SPI and not the Focus SPI. The Escort SPI is a drop in and go, while the Focus SPI has some differences making it a harder swap. So we cant be blamed for the shortage.
Agreed.. however some escort owners use the focus shortblock which is a direct bolt in as far as I know.
I've bought 2 2.0 SPI's for around $300.
I'm assuming these were escort spi's. I called about 20 junkyards and they immediately knew about the shortage and said they get calls everyday for the focus spi motor. They would not lower there prices because they know they can get what they are asking.
I'm sure this is possible but it would not be easy and would probably set off all kinds of CEL's. Hats off to you for making it work with your 1.9 ecu.
2003 Ford Focus Silver Sedan LX SOHC Automatic
1997 Pontiac Supercharged Trans Am WS6
Sedan Revolution #135
cardomain.com/ride/3145658
FocusPilot is offline
Old 11-06-2008, 07:54 PM   #13
jeffescortlx
Fan#: 28343
I dont know of any Escort owners that have used the Focus SPI Block, head yes, but block no. I dont think there is mounting pad on the back of the focus block since the foci uses the head for mounting.
yeah there would be a CEL since there is no IMRC, and the Cam sensor timing signal might be off, forcing the ECU to fire the injectors in batch mode, not the end of the world.
But if I could save about $1000 only to have a CEL on I would. Plus no worry of valve seat droppage. That if I dont have to pass emmition inspections.
Old 11-08-2008, 05:32 PM   #14
FocusPilot
FocusPilot's Avatar
Fan#: 58694
Points 340, Level 6
Ya I agree you could probably save a little money by buying a used zetec and jerryrigging the computer. I just figured if I was going to spend the time to put a motor in I would want a new motor and not alot of hassles. I weighed the time vs money thing and I felt my time was worth more than the money I would save. Everyone is different and what right for one persons car may not be right for anothers. I also feel it is important to keep a car as close to stock as possible for parts availability and resale value. Just my 2 cents.
Old 11-10-2008, 01:36 AM   #15
cagedcbr
cagedcbr's Avatar
Fan#: 58822
What I Drive: '01 Oxford White Wagon
FF Reputation: 1 cagedcbr Good Standing Member
We had our wagon for 2 weeks and the motor let go on us, the total cost of replacing it was $2300. The cheapest motor aroound (and the only one) was 1600 bucks the rest was labour (other stuff was repaired aswell). I had 4 shops calling around for a motor and believe it or not they all got back to me with the same motor, which was located at the biggest scrapyard we have up here. I will say though I wish I had waited because not to long after that I was offered a complete Roush turboed Zetec for $3000, from wiring to trans to shifter and guages
cagedcbr is offline
Old 11-10-2008, 01:54 AM   #16
dcorwin822
dcorwin822's Avatar
Fan#: 53054
What I Drive: 2008 Vermillion Red SES
Points 3,295, Level 35
Points: 3,295, Level: 35 Points: 3,295, Level: 35 Points: 3,295, Level: 35
Level Up 64% Completed
FF Reputation: 11 dcorwin822 Great Standing Member
i remember my escort days... i beat the snot out of my CVH motors but both held up... (two escorts both rotted away) just a little smoke on start (bad valve seals) but after that what a champ!
I got rid of them 'cause my friends started passing me water bottles and gum through the wheel wells while i was doing the breaks...
I also miss the winter fun in them though... freezing your ass off cause of the little missing ball in the t-stat housing but oh well.. sliding into curbs and thinking... mehh whats out of my pocket 700 bux? thank you ad's in the paper. and a managed 35-40mpg on the highway back and forth from school at the time.
anyone need a complete 91 valve head with cam and gears? all its missing is the cover
dcorwin822 is offline
Old 11-10-2008, 11:17 AM   #17
tin_maddog
tin_maddog's Avatar
Fan#: 23749
What I Drive: Pitch Black SPI, b!tches!
FF Reputation: 4 tin_maddog Good Standing Member
Talking
Because it really seems like you take care of your stuff...
Who Watches the Watchmen?
Integument is gross -- it's nothing more than a sack of guts.
Daniel San didn't let the wax dry.
uberSPI
tin_maddog is offline
Old 11-10-2008, 02:51 PM   #18
dcorwin822
dcorwin822's Avatar
Fan#: 53054
salty NY roads... 700 dollar escort in the paper... got 2.5 years out of it before i traded it in for my 08 focus
Old 11-12-2008, 03:11 PM   #19
Als RS8
Als RS8's Avatar
Fan#: 53271
What I Drive: maroon lx
FF Reputation: 1 Als RS8 Good Standing Member
Originally Posted by focusmcfly View Post
Some may have seen my post about the engine taking a dump on my 2.0 2000 spi focus. I decided I want to try and rebuild the engine myself. I might as well since its apart and out. I found the pistons online for under $200 and the head rebuilt with a 2 year warranty on ebay for about $300. I need to know a few things before proceeding.
1. How do you press the rods off and new pistons on ?
2. How much torque do I use when attaching the rod and bearing back on the crank? (Is there anything else I should know here as well)
3. Do I need new bearings?
4. If the cylinders look in good shape do I have to hone them?
5. Is it even wise to attempt a rebuild without experience?
Engine had less than 80,000 miles on it before valve seat fell and killed everything.
Thats about it. I have worked on cars doing various things over the years. But have never attempted a rebuild.
know what your getting into its a pain without the right tools
1 cam shafts , lifters and rocker armrs-removal and installation
removal
disconnect the negative cable from the battery
remove the air cleaner intake duct
remove the valve cover
remove the drive belt
remove the flange bolts and remove the fulcrums rocker arms, lifter guide retainer,lifter guides and lifters.Keep components in there originally installed
sequence by marking them with a piece of numbered tape or by using a
suitable sub divided box(such as an egg carton). If the lifters are not marked
with color codes, be sure to mark each lifter so you know which end faces the front of the engine, since you must reinstall the lifters so they rotate in
the same direction they originally did.
remove the ignition coil pack
remove the timeing belt
pass a rode or large screw driver through one of the holes in the cameshfaft
pulleyto lock it and unscrew the sprocket bolt. Remove the sprocket.
remove the two bolts and pull out the camshaft thrust plate.
remve the cup plug from the transaxle end of the cylinder head.
carefully withdraw the cam shaft from the transaxle end of the cylinder head
Installing the camshaft and rocker arms is the reverse as the removal
2 Torque specifications ft lbs
camshaft sprocket bolt 77
cam shaft position sensor 180 in lbs
cam shaft thrust plate to head bolts 89 in lbs
crank shaft damper bolt 88
rocker arm bolt 18
ALL INFORMATION FROM FORD FOCUS REPAIR MANUEL
GENERAL type in line four cylinder, SOHC
engine vin code P
displacement 2.0 l (121cubic inches)
bore 3.34 inches
stroke 3.46 inches
fireing order 1342
3 yes
4 always
5 rebuilding an engine is easy if you fallow the repair maneul instructions.
Als RS8 is offline
Old 11-12-2008, 08:42 PM   #20
arrestmespi
Fan#: 27586
What I Drive: '04 Mazdaspeed Mx-5, '72 M35A2
FF Reputation: 27 arrestmespi Great Standing Member
Buy-Sell-Trade Rating: (8)
thermite + crucible = only thing to do to an spi
arrestmespi is offline
Similar Threads
BMW M3 Convertible Tom Ford Focus & General Car Chat 11 03-23-2008 01:09 PM
For Sale: SPI Engine Belt Tensioner, New! SuperFlea Archive 13 11-19-2007 04:35 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
For Sale: '00 2.0L SOHC SPI engine KrazedZ Archive 1 11-18-2005 09:33 PM
SPI engine removal wcbjr SPI Performance (2000-2004) 12 11-03-2005 10:15 AM
