#21 | ||||
Thanks
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance. Last of the Hatches #28 |
#22 | ||||
I have been trying all afternoon to get the upper mounts adjusted correctly. Its not happening.
#24 | ||||
Ref what you said about the upper arm bushings. I had the SPF adjustable upper arms installed. Wunder if they got those in right and tight? Sick of dorking with the shocks. Made a rubber mount but want to go with WD40 idea. Only where do I get the bushing and washers?
#25 | ||||
Update: I made some temporary semi-solid shock mounts. These got rid of a lot of the problem, and allowed me to find one major one which I don't know how to fix. There are tailgate 'snubbers' on each side of the hatch. The drivers side def shows where the snubber is contacting the body (as it should). The passenger side however does not appear to be working at all, and that is where the noise seems to be coming from, especially if I hit a moderate dip. The OEM snubbers are non-adjustable. How should I deal with this? The body/hatch alignment is perfect on the outside.
Thanks
#26 | ||||
The Librarian
Not sure about your hatch problem...
But... Made a rubber mount but want to go with WD40 idea. Only where do I get the bushing and washers? The bushings I used for the rear shocks came off some Rancho shocks I had on my Bronco. Any parts store should stock them. Just ask for poly shock mounts, and get the diameter that will fit your shocks.
WD40 Reverend GripShift - FF Moderator Member's Rules and Signature Guidelines Member FAQ and Information Archive Complete 'How To' Archive Complete Acronym/Abbreviaton and Forum Terminology List |
#27 | ||||
Hmm. Ya! Thats why I wanted a pic WD40. The Ford shocks (for me year anyway) have a plastic cover at the very top that has plastic clips that come through the top mount and serve to center the shock. I played with some bushings and cannot see a way to incorporate them (not enough threads left). The mounts I made have a 5/8" hole in the center to clear these clips. Thats pretty big for a standard bushing.
Hatch problem I know how to fix, just was hoping someone had done it before so I don't have to hunt up the parts (which can take a long time).
#28 | ||||
Update: The rear hatch snubbers ARE adjustable. All better now! (Do I get the 'i am blind' award?)
#29 | ||||
I drive this!
Isn't the oem spec on the rear upper shock bolt like 13 ft/lbs or something insanely low?
"When does the zetec kick in" Asked by a Honda enthusiast |
#30 | ||||
The Librarian
^^^You got it...13ft lbs.
But...you may not need them. These are what I used: ![]() That "shoulder" if you will (raised portion on the bushings on the left) is exactly the same size as the hole in the car body where the shock goes through. That in itself centered the shocks. I used the existing lower washer, and new uppers that I had with the bushing. Note: You will have to measure the hole in the body to make sure you get bushings with the same size shoulder. I just happened to luck out, and what I had lying around from the Bronco fit perfectly.
Similar Threads
| The Ford Focus Parts List! | gthang | MK2 Focus | 13 | 01-26-2009 11:05 PM |
| LPE Rear Shock Mount Shims | focusonthis420 | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 6 | 04-26-2008 02:38 PM |
| Clunking noise from rear of Stock SVT | SVTF4243 | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 9 | 12-13-2007 10:56 PM |
| Idea to spruce up a stock rear bumper...cheap idea...need opinions | J-Dawg | MK1 Focus | 33 | 01-11-2005 12:22 PM |
| rear shock mounts | jeremy | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 2 | 02-04-2004 02:33 PM |
