"How To" - VF Engineering Rear Mount-Install Pics - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2010, 10:19 PM   #111
loudfocus01
loudfocus01's Avatar
Fan#: 26006
What I Drive: 2001 White LX 2002 Infra-Red Svt
FF Reputation: 107 loudfocus01 Excellent Standing Member loudfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (17)
Old thread, but its in the how-to archive.
Used this to install my CFM lower mount today on my SVT.
So much easier of an install on the SVT than it was on my sedan.
LOVE the results! The shifting and overall feel of the car is AWESOME now!
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
loudfocus01 is offline
Old 05-31-2010, 07:35 PM   #112
alexdc
alexdc's Avatar
Fan#: 51995
What I Drive: 2003 Pitch Black SVT Focus ZX5
FF Reputation: 2 alexdc Good Standing Member
can you tell me how the it took my 2 hours and i just break a bolt!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THIS car is a headache since i bought it.
alexdc is offline
Old 03-18-2011, 12:03 AM   #113
oblivion2kx
Fan#: 61764
What I Drive: 2004 Twighlight Blue 2.3l ZX5
FF Reputation: 2 oblivion2kx Good Standing Member
installed mine today .. that bolt to the chasis was a bitch and a half.
I ended up using a 4 ft breaker bar to loosen it's 100k death grip.
A few years ago, I went to the gym for several months and lost 30 pounds. That must be worth about 1% more fuel economy in the city.
oblivion2kx is offline
Old 02-18-2012, 06:11 PM   #114
dtecPwr
Fan#: 54622
What I Drive: 2003 Comp Orange SVT 3 door #2176
Points 1,562, Level 22
Points: 1,562, Level: 22 Points: 1,562, Level: 22 Points: 1,562, Level: 22
Level Up 62% Completed
FF Reputation: 2 dtecPwr Good Standing Member
Alright so today I was trying to install my new cfm dogbone mount and the bolt that goes through the mount and into the subframe BROKE IN HALF!!!!
Half of it came out but the other end is stuck in there. How can I get it out of there???
you can see the rusty part of the bolt on top where it's sticking through the weld nut, stupid corrosion weakend the bolt....I am tired of this car fighting me on everything simple thing I try and do to it!!!!
I live my life one corner at a time
dtecPwr is offline
Old 03-21-2012, 07:57 PM   #115
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,738, Level 58
Points: 7,738, Level: 58 Points: 7,738, Level: 58 Points: 7,738, Level: 58
Level Up 94% Completed
Forum Activity 25%
Buy-Sell-Trade Rating: (15)
Well im in a bind....
Got the two bolts out of the mount and now I cant get the mount out or even back install the way it was.
Seems the transmission has shifted its weight towards the subframe and I cant move it to get it lined back up. I can one of the bolts in but not both, let alone the old mount out and the in on in its place.
Any tips or tricks? How do i man handle this to get it aligned?
rambleon84 is online now
Old 03-21-2012, 08:27 PM   #116
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 25%
Well I'm giving up on this for tonight, just getting frustrated and no results
So worst case scenario and I cant get it installed. Would it be ok to drive the car 1.5 miles to the shop i normally get stuff done at with out the lower mount attached? Say if i drive like a complete grandma or would that destroy my other two mounts or worse?
Old 03-22-2012, 12:20 PM   #117
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 25%
Bump, any suggestions for when I try to tackle this again tonight? I just cant get any leverage while laying on my back to get the trans moved back enough to get the old mount out. I can move the tranny only a little and not enough. Any ideas on what caused my tranny to move towards the subframe? I could clearly see that the wood I used to support the tranny had been moved towards the frame by a couple inches as it was running into the frame where as when the mount was still bolted in, i had an inch between the block and the frame.
Old 03-22-2012, 02:01 PM   #118
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,369, Level 61
Points: 8,369, Level: 61 Points: 8,369, Level: 61 Points: 8,369, Level: 61
Level Up 73% Completed
Forum Activity 42%
pick up a set of ratchet straps do you can position the engine / transmission for the install... The engine is not balance weight wise with the transmission attached so the assembly will shift as a result of having more weight on one side vs the other... the factory side mounts are "soft" so will provide more movement then you may think.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 05-15-2012, 05:21 PM   #119
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
What I Drive: 2013 Performance Blue ST
Points 1,170, Level 18
Points: 1,170, Level: 18 Points: 1,170, Level: 18 Points: 1,170, Level: 18
Level Up 70% Completed
FF Reputation: 1 LiciouzSVT Good Standing Member
I've did this mod on about 6 different foci and it took no longer than 30 mins each time. I guess I have just had some pretty good luck with the bolts coming right out. It could be that I am just a beast!
LiciouzSVT is offline
Old 08-24-2012, 12:09 AM   #120
AlexCA
Fan#: 102754
What I Drive: 2003 Charcoal Grey ZX3
FF Reputation: 1 AlexCA Good Standing Member
I need to replace the mounts on my car. Are the OEM mounts good, or should I purchase aftermarket?
AlexCA is offline
Similar Threads
"How To" SVTF Short Shifter Install WD40 SVT Performance (2002-2004) 209 07-07-2012 12:25 PM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
CFM trans mount vs. VF engineering with pics macdiesel General Technical Chat 9 07-02-2010 08:44 AM
**Vote for Focusfanatics.com Ride of the Year 2009** (PHASE 1) Chick Ford Focus - Ride of the Month 30 08-01-2009 08:46 PM
Rear Camber Bolt Install eurotrashvrt Brakes, Suspension & Body Chassis 5 06-11-2007 04:00 PM
