ST170 Intake Manifold Runner Control disassembly (PICS!!) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-24-2008, 09:54 AM   #1
GuySA
Fan#: 56787
What I Drive: 2004 Imperial Blue ST170
FF Reputation: 8 GuySA Good Standing Member
Well evan's post the other day "http://www.fordstownerssa.co.za/foru...p?f=20&t=16812" got me thinking. I didn't think the IMRC box could be opened before he said he opened his up, so I decided to remove, open, and have a look at mine. My car had been throwing the code P1518 a lot recently, which has to do with the IMRC malfunctioning.
Well what evan doesn't mention is that due to the positioning and way that the IMRC is mounted removing it is a *!!! Don't even try it unless you have a quality 10mm ratchet spanner and a fair amount of patience, and don't mind skinned knuckles and fingers.
Once its off though and you remove the cover held on by four screws this is what you will see.
A circuit board, a johnson 540 motor (as used in almost all basic radio control cars), and a cascade of metal gears, all rather simple and rugged looking.
In order to have a look at the other side of the circuit board I had to remove the 6 screws holding the board to the case and the black electrical connector. The connector is securely epoxied in place and can't be removed. I also had to de-solder the six connections between the board and the electrical connector.
On the underside of the circuit board you can see the points that are activated by the cam on the white plastic wheel that pulls the cable. The points are held open when the car is off or when the IMRC is in the high speed position. At any other time the points are supposed to be closed.
When I disassembled mine the points looked to barely be touching in the closed position and I assume this may have been the cause of my fault code, namely, the points perhaps not being closed properly with the IMRC in the slow speed position.
I gently tweaked the copper points spring with some small pliers to try increase the pressure on the points in the closed position as well as cleaned out the contacts with methylated spirits.
Careful examination showed all the joints on my circuit board to look okay so I gave the gears a small amount of grease and reassembled the circuit board and motor into the housing.
Fitting the IMRC back into the car was a bit easier than removing it, especially with the help of my father.
I then reset the engine light by disconnecting the battery, 30 seconds to a minute is all thats needed, and started the car. That was 22 June '08 and since then the fault has yet to return. I will keep this post updated as to whether it does return or not.
Enjoy
Guy
GuySA is offline
Old 06-24-2008, 10:10 AM   #2
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
FF Reputation: 34 tukaniSVT Great Standing Member
Wow ... Great Job with that.
I would have not even thought about opening that up... but now ...
tukaniSVT is offline
Old 06-24-2008, 10:12 AM   #3
NA_Built
NA_Built's Avatar
Fan#: 30476
What I Drive: Stock 01'
Points 672, Level 13
Points: 672, Level: 13 Points: 672, Level: 13 Points: 672, Level: 13
Level Up 44% Completed
FF Reputation: 1 NA_Built Good Standing Member
Sweet
25 years old and I still like seeing things taken apart.
weird
NA_Built is offline
Old 06-24-2008, 10:19 AM   #4
focisvt03
focisvt03's Avatar
Fan#: 2071
What I Drive: 03 Focus SVT Yellow EAP
FF Reputation: 46 focisvt03 Great Standing Member
What is the IMRC box what does it do, what kind of problems does it cause, and where is it? Sorry I'm new to all this and am trying to learn
Even heros have the right to bleed!
focisvt03 is offline
Old 06-24-2008, 10:24 AM   #5
GuySA
Fan#: 56787
It controls the dual stage intake manifold. Its the silver box bolted to the firewall.
I causes the code listed in the post to appear and can reduce low end torque if it fails.
No need to apologise, just use the search function and read up on past posts, most of what you ask has been explained before at some stage, sometimes in depth.
GuySA is offline
Old 06-30-2008, 04:26 AM   #6
GuySA
Fan#: 56787
UPDATE: A week and almost 600kms down and still the error hasn't returned. :)
GuySA is offline
Old 06-30-2008, 05:24 AM   #7
zx505focus
AKA KILLA XB
zx505focus's Avatar
Fan#: 44497
What I Drive: 2010 Scion XB RS7
Points 10,155, Level 67
Points: 10,155, Level: 67 Points: 10,155, Level: 67 Points: 10,155, Level: 67
Level Up 27% Completed
FF Reputation: 44 zx505focus Great Standing Member
Buy-Sell-Trade Rating: (19)
well im getting code P2004, and its said IMRC open bank 1, could you help me with that. its a 05 2.0 duratec engine.
Murasaki Warrior
zx505focus is offline
Old 07-02-2008, 04:38 PM   #8
Hillyard
Supercharged
Hillyard's Avatar
Fan#: 10982
What I Drive: 2002 ZX3 SVT, 2004 Ford Ranger 4x4
Points 13,364, Level 75
Points: 13,364, Level: 75 Points: 13,364, Level: 75 Points: 13,364, Level: 75
Level Up 29% Completed
FF Reputation: 2 Hillyard Good Standing Member
Buy-Sell-Trade Rating: (27)
The SVT Zetec and your Duratec engines don't have the same intake manifold. Your Duratec engine doesn't have this box to control the dual stage intake runners. It is exclusive to the SVT model.
#3788 InfraRed SVT
Hill <><
Hillyard is offline
Old 07-02-2008, 06:28 PM   #9
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
Points 31,982, Level 100
Points: 31,982, Level: 100 Points: 31,982, Level: 100 Points: 31,982, Level: 100
Forum Activity 6%
FF Reputation: 104 besthaticouldo Excellent Standing Member besthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Originally Posted by NA_Built View Post
Sweet
weird
agreed...
thats freaking awesome
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Old 07-04-2008, 07:21 AM   #10
GuySA
Fan#: 56787
Yeah, sorry zx505focus I don't have any knowledge of the Duratec intake system.
GuySA is offline
Similar Threads
"How To" CFM Silicone Couplers for SVTF Intake Manifold mike 1 SVT Performance (2002-2004) 27 02-24-2011 02:36 PM
intake manifold runner stuck open? svtfocus_john SVT Performance (2002-2004) 17 09-21-2010 03:15 PM
Intake Manifold? giantsnyy ZETEC Performance (2000-2004) 14 05-26-2007 02:39 PM
Intake Manifold Runner Control? sidney61199 SVT Performance (2002-2004) 16 12-16-2006 05:23 PM
tom: pics of your new intake manifold? hurtinfocus Focus-Power Tuning 2 09-25-2005 07:08 PM
