Is this a good wheel/tire choice for G stock/STN - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Racing Discussions > Autocross Racing
Old 06-17-2008, 02:18 PM   #21
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Originally Posted by Killercanary View Post
Dirtydeeds- Thanks, I'll try that next time out. The only reason I'm running them so high is because even at 44-46lbs up front, the side walls show scuff signs. I will try it though.
Thanks! I do check it after every run, and you are right, it goes up 1-2lbs every run. If I do have to wet the tires, should I wet them and then check the air, or doesn't it really matter?
There are a couple of different camps on the "wetting issue".
I personally am indifferent. So, I'll let you draw your own conclusions.
1 camp says that the temperature goes down by cooling with water. You can off set this by reducing the tire pressure. Wetting the tire reduces traction by launching with a wet tire.
The other camp says that cooling the tire with water reduces greasiness of tires as temperatures increase.
I can't tell you if one is better than another.
My experience is that monitoring the pressures is the most effective way to maintain/increase traction.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Similar Threads
What is a good driver? gthang Ford Focus & General Car Chat 51 08-29-2008 10:34 AM
rota slipstreams (16X7) wrapped in falken azenis RT-615's. good choice for autocross? svtff1213 Autocross Racing 19 08-24-2007 07:33 PM
got pics of bad sycros or specs for good ones? How can I tell if its good? heelflip101 General Technical Chat 5 05-27-2007 03:39 PM
Good times remembered Evo Foci Ford Focus Builds & General Showroom 20 02-23-2005 07:30 PM
