#31 | ||||
Definately would work - but I think that you'd really be lacking enough spring up front to control body roll/contact patch - what you gain in the rear you'd lose at the front.
There is a new set of springs - M-5560-ZXM - out for this year that are a replacement for the multimatic springs, but drop the car another 1/2 inch or so more than the multimatics. Also may be a touch stiffer as well. I'm putting them on my car. I think they are around $200 or so, so picking up a set to mix and match with your current springs is definately do-able and cheap. Not sure if they are available yet, but should be available by Jan 1. Check with Capaldi, McNews, CFM, or any of the other sponsors on the board.
2007 Spec Focus NASA National Championships - 4th place 2007 NASA Mid-Atlantic Spec Focus Champion 2006 NASA Mid-Atlantic 944 Supercup Champion Spec Focus Advisory Board - Have a Spec Focus Question? Ask me! |
#32 | ||||
the anti-roll bars arent limited to being unmodified, only that they are under a certain diameter, i wonder if it matters if they are hollow or soild? also i could weld in an adjustment bar, and calculate the different roll stiffnesses and figure out the balance of front to rear roll stiffnesses, i think that becuase its a spec suspension we need to figure out a way to optimize it... would it be out of the rules to put small washers between the upper strut mount and the shock tower to corner balance the car? ive heard of someone doing this before with good results, however im not entirely sure about the legallity in our series. or maybe imthinking to hard and i should just build the car and have fun. anyways just random ideas.. have you driven on the R888's? ive heard they stick harder than the RA1's which i have driven on.... i think that i could analzye the exhaust system and header on wave and fluent, along the the cold-air intake, and optimize them and maybe come close to the power i want. if you can tell i like expirementing and figuring stuff out, im on the FSAE team at UTA, we are in the process of building our 2008 car and im getting inspired with some of their ideas
Matt |
#33 | ||||
Or you can just purchase one of our cars that is for sale and it is turn key ready to go.......
As for the Cossie manifold there is a lot of data that shows you lose torque with the manifold...even if you tune the car with all of the parts you will still see lower torque numbers than compared to stock. To see what I am talking about take a look at the FS turbo kits with stock and cossie manifolds. Again please note this manifold is a great product but ideally works better and flows best above 8,000 rpms..... Even though these cars will be used through out the year these cars are also for sale. With the addition of a 2008 Sedan and another 08 later in the year we figured we would put this out for someone that might want to purchase Spec Focus Race Cars. One is a 2003 (w/05 Front End) and the other is 2001 Focus, both are ZX3's with Full cages and race seats and nets on window and right side seat net. Below is a brief list of the items each has.... 2003 Focus: 2.3L Duratec Engine 5-speed with Torsen Full Cage w/fire system Tow hooks front and rear Built to full spec rules..... AIM Digital Display Sparco Seats and OMP steering wheel Toyo R888 tires Lexan Driver and passenger windows Still can be driven in the street as it is still registered Car has 12,000 miles 2001 Focus: 2.0L Zetec Engine w/racing head Full cage with w/fire system complete ac system still working aftermarket radio still works Sparco Seats and Sparco Racing wheel Toyo R888 tires The car has a salvaged title but still street driven Car has 54,000 miles Tow hooks front and rear 5-speed with Torsen and Ring and pinion Built to spec rules. Both cars are ready to race for next season and are also ready for sale. The best option for a turn key race car that you can still drive on the street for a bargain price given everything you are getting. Both cars a available for $8500.00 each (firm on the price), by far the best bargain for the dollar! Please call us at 562-698-3000 or e-mail us at ricardo@f2usa.com.....thanks and take care. |
#35 | |||||
#36 | ||||
FWIW - I had my car shipped from San Diego to Virginia - cost was just under $600
#37 | ||||
the ride height difference would be about a 1/4 to 3/8ths of an inch difference, so i dont find it to be unreasonable, also i drove a good freind of mines spec miata before and after corner weighting... huge difference. i could deffinatly work on the exhaust, i figured out an exhaust for my WRX and it picked up 13whp 14lb-ft of torque, and it only weighed 9lbs, then i sold the exhuast because some guy loved it, i didnt really like the sound anyways, but i could deff build one for the focus, im thinking 2.5in with a mangnaflow flow-though race muffler but ill so some more research. Matt |
#38 | ||||
Here's the swaybar rule:
Rear anti roll bar diameter may not exceed 25 mm. Rear end link and bushing material may be changed but must mount to the anti roll bar and subframe in the original manner with a through-bolt and sandwiched, non-adjustable flexible bushings
#39 | ||||
so it must mount to the subframe in the same manner, but the pick-up point along the control arms can be changed im guessing as it is not defined as a limitation, my guess is that you could easly make the rear sway bar more effctive in this manner
Matt |
#40 | ||||
I think you'll run afoul of the of the "no other changes are permitted" that aren't specifically allowed catch-all rule. See section 18 of the rules.
Similar Threads
| Ford debuts Focus Coupe-Cabriolet | Kneel | Ford Focus & General Car Chat | 50 | 10-02-2011 07:04 PM |
| Australia gets the new Focus next month | Kneel | Ford Focus & General Car Chat | 27 | 11-26-2007 08:17 PM |
| Soon to come, more SVT parts for your non-SVT Focus... | myFordPerformance.com | ZETEC Performance (2000-2004) | 33 | 01-02-2007 11:41 PM |
| Body/Lip Kit Companies | S2 | MK1 Focus | 1 | 12-04-2004 04:20 PM |
| Focus 1.8L Zetec UK spec | Michael306D-Turbo | ZETEC Performance (2000-2004) | 4 | 09-01-2004 03:06 PM |
