sporadic's Turbo Duratec build thread - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-25-2007, 12:53 PM   #21
jrpasmo
jrpasmo's Avatar
Fan#: 2866
What I Drive: 02Focus ZTW, 02Focus SVT
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
FF Reputation: 5 jrpasmo Good Standing Member
Why only 0.035 gap ? how much boost u planning to run ?
jrpasmo is offline
Old 07-25-2007, 01:15 PM   #22
sporadic
sporadic's Avatar
Fan#: 12724
Points 12,680, Level 73
Points: 12,680, Level: 73 Points: 12,680, Level: 73 Points: 12,680, Level: 73
Level Up 58% Completed
Buy-Sell-Trade Rating: (12)
Only reason is that's what Randy runs in his Focus Sport turbo kit.
The fab work I can do (which is the majority of this work)... it's the tuning etc I have to lean on other folks for, so I went by what Randy has on his website.
So when you ask "why", I don't know. Ask Randy. :)
Oh, and I'm running 9.5psi - the stock boost for the IHI wastegate.
No boost controller because I won't be straying from that.
sporadic is offline
Old 07-25-2007, 01:38 PM   #23
jrpasmo
jrpasmo's Avatar
Fan#: 2866
Hmmm I'm running around that same PSI with my Procharger...having them gapped to 0.055 no problem....just wanna let u know ....
jrpasmo is offline
Old 07-25-2007, 02:11 PM   #24
fokuzx3
teh tranny killer
fokuzx3's Avatar
Fan#: 15685
What I Drive: r.i.p. liquid grey zx3....now 300zx
FF Reputation: 1 fokuzx3 Good Standing Member
jeez youve put alot of hours into makin this thing happen, i think i would opt to go for the fs turbo lol ... seriously though, how much money you think you have saved by doing it yourself vs the 4k turbo kit?
zetec crew #23
zetec R.I.P. best standing 1/4 time= 15.260 @88.08 mph (2.275 60)
Originally Posted by warneej View Post
it takes a minute to get used to, kinda like shaving your balls.. haha
fokuzx3 is offline
Old 07-25-2007, 02:48 PM   #25
jrpasmo
jrpasmo's Avatar
Fan#: 2866
^^^ Just read his first post and u'll understand that is not about $...
"Doesn't somebody make a kit??
Yep. Randy at Focus Sport sells them for a mere $4,000.
I'd personally rather have no turbo at all than to spend that much, learn nothing, and barely lift a finger.
That's just not me.
jrpasmo is offline
Old 07-25-2007, 03:26 PM   #26
Bigfonsz
Bigfonsz's Avatar
Fan#: 20407
What I Drive: 2002 SVT Turbo ZX3
FF Reputation: 9 Bigfonsz Good Standing Member
Buy-Sell-Trade Rating: (10)
.55 that can't be right
Bigfonsz is offline
Old 07-25-2007, 03:44 PM   #27
jrpasmo
jrpasmo's Avatar
Fan#: 2866
heheh read it one more time ... 0.055 ;-)
jrpasmo is offline
Old 07-25-2007, 09:05 PM   #28
sporadic
sporadic's Avatar
Fan#: 12724
Thanks much. I'll talk to LaSota Racing and see what he thinks and let you guys know.
sporadic is offline
Old 07-25-2007, 09:06 PM   #29
sporadic
sporadic's Avatar
Fan#: 12724
That's just not me.
You got it right, sir.
I'm having a blast and learning more every day.
It's not work if you're having fun.
sporadic is offline
Old 07-25-2007, 11:20 PM   #30
sporadic
sporadic's Avatar
Fan#: 12724
Day 9
Start time: ~5:30pm
End time: ~10:45pm
Dan finished up my oil pan a day early!
I'm quite happy with how the return tube turned out!
I ended up trimming it down about 2".
Today I got the oil pan reinstalled, and that's about it.
Cleaning the old oem RTV off took a while.
I cleaned the gasket surface about 3 times with mineral spirits before applying the new RTV and installing the pan.
The Haynes manual states to remove the transmission in order to remove the oil pan. I did not.
It was a tight fit, but it does come out and go back in without removing the tranny.
The only concern would be proper sealing of the pan against the timing cover.
I suppose I'll find out soon enough if I did it correctly. Seems ok at first glance.
I started removing the intake manifold.. man what a pain.
I'm revamping the stock PCV system so all air is from and back to the atmosphere.
That way the cruddy oily fumes won't gunk up my intake tract and at the same time throw off my tune.
Assumming all goes well my tune date is Friday August 3rd!
I plan on working like a mad man this weekend to get the car completed.
What's left (off the top of my head):
- Exhaust from the cat back, using mandrel bends but nothing is welded or cut to length yet
- Reassemble "good" turbo
- Route oil feed a return lines
- Splice into coolant lines and route to turbo (one of the last things I do)
- Install gauges and route lines. (Boost and Oil Pressure)
- Redo PCV system
- Reinstall and clamp intercooler piping
- Install base "no boost" tune
PICS
Oil pan with drain tube:
Before trimming the tube.
It's slightly below the oil line.
Pan with baffle installed:
Oil pan installed:
A couple of random pics of the test-fit turbo from beneath the car:
sporadic is offline
Similar Threads
Custom turbo build jamfrank General Forced Induction 17 06-02-2008 12:07 PM
Duratec oil sending unit thread size sporadic General Forced Induction 1 07-24-2007 12:36 PM
duratec turbo kit for 2k????? for real!!! brandon0133 General Forced Induction 4 04-30-2007 01:35 AM
500hp Zetec Turbo Build, 180mph target. ukfoc General Forced Induction 30 10-08-2004 09:39 PM
