Double Checking AutoX Classification - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Old 07-01-2007, 09:47 AM   #1
FocusVet
I'm Back!
FocusVet's Avatar
Fan#: 41812
What I Drive: '03 Twilight Blue Sedan-D23E
FF Reputation: 19 FocusVet Great Standing Member
Buy-Sell-Trade Rating: (9)
Arrow Double Checking AutoX Classification
I read the rule book from front to back and I just wanted to double check my mods before I go racing. I'm looking for the H-Stock classification.
A-I removed my CAI, STS and Tower Strut bar.
B-This is what I have left on my foci
1) Focus Sport cat-back exhaust
2) Front H&R Sway Bar
3) SVT Pedals (Will I slide w/this?)
4) OEM Size Toyo Proxis Tires
5) RS Shifting Knob & Steering Wheel (Sure this dosen't matter)
So.........I figure I'm OK for the H-Stock Class, and If I leave my mods on, then I'm in to the STS Class, AM I READING THE BOOK CORRECTLY????
Thanks all you autoxer's for the input!!
TEAM DURATEC # 074 / SEDAN REVOLUTION #001
FocusVet is offline
Old 07-01-2007, 02:26 PM   #2
focusedaddiction
2focusedracing
focusedaddiction's Avatar
Fan#: 23787
What I Drive: 2003 sangria red 5spd. ZX3Turbo
FF Reputation: 4 focusedaddiction Good Standing Member
Buy-Sell-Trade Rating: (14)
You should be fine for H-stock, which model tires you running? you should be allright as long as they're not DOT competition like the RA-1's
_/\_/\_SCCA_/\_/\_SM #74_/\_/\_BRING ON THE CONES!...zetec crew #74
ZX3..underpressure
tuning by TOM
focusedaddiction is offline
Old 07-01-2007, 03:10 PM   #3
dubalicious
dubalicious's Avatar
Fan#: 33589
What I Drive: 2004 SVT Focus, I call her Vera.
FF Reputation: 2 dubalicious Good Standing Member
You should be fine, don't mention the SVT pedals and you should be fine, only someone real assholic will put you in a different class for pedals.
The beatings will continue until morale improves.
dubalicious is offline
Old 07-01-2007, 08:20 PM   #4
eventerke
eventerke's Avatar
Fan#: 41299
What I Drive: 2002 Pitch Black SVT
FF Reputation: 3 eventerke Good Standing Member
IIRC, Stock classes *can* run DOT race compounds - nearly all the fast people in my club do.
You have to use genuine *street* tires in STS/X/U etc. classes.
eventerke is offline
Old 07-01-2007, 08:39 PM   #5
FocusVet
I'm Back!
FocusVet's Avatar
Fan#: 41812
My current tires are TOYO PROXES TPT(OEM size on my OEM 15" rims)
http://www.toyo.com/docs/tires/tires...gory=passenger
Also, if I leave ALL my mods on, then do I belong in the STS class? Here's a noob question, Does your number get assigned to you, or can you choose your own? Ex. 100HS or 100STS
FocusVet is offline
Old 07-01-2007, 08:41 PM   #6
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Not so fast...
Is the sway bar the stock dimension? If so, you should be fine.
If it is larger, that puts you in prepared (unless it is the same diameter as an SVT bar).
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 07-01-2007, 08:46 PM   #7
FocusVet
I'm Back!
FocusVet's Avatar
Fan#: 41812
Originally Posted by WeeAsp View Post
Not so fast...
Hmmm.....I'm not sure? It says 24 for the size? Here's the H&R Link:
http://hrsprings.com/scripts/testappguide.php?Mode=Application+Guide2&SubMode=Find2&Year=2003&ModelID=182&q=2003%20|%20Ford%20|%20Focus
FocusVet is offline
Old 07-01-2007, 08:48 PM   #8
SVT Robzor
SVT Robzor's Avatar
Fan#: 26230
What I Drive: 2004 CD Silver SVT
FF Reputation: 5 SVT Robzor Good Standing Member
The front sway bar is a free modification in stock class, as I understand it... any change to the rear sway bar or the links is a class bump. Any DOT tire on the rim is fine, as long as the rim is the same width and diameter, and within 1/4" / 6mm of the OEM offset. Or is it 5mm?
2004 SVT Focus
Custom front-bumper-mount bug guts; precision sprayed brake dust on OEM rims; 15% Pine Tree pollen over the clear coat.
No more SVT autocross, I drive the thing in the avatar.
SVT Robzor is offline
Old 07-01-2007, 09:03 PM   #9
FocusVet
I'm Back!
FocusVet's Avatar
Fan#: 41812
I reread the rules, and it sounds like to me at least "alternate" front sway bar is OK for stock class. But it's a NO NO for a rear sway bar.
FocusVet is offline
Old 07-01-2007, 09:21 PM   #10
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
I stand corrected.
Here is the section.
13.7 ANTI-ROLL (SWAY) BARS
A. For front anti-roll (sway) bars:
1. Substitution, addition or removal of any front anti-roll bars is
permitted.
2. Substitution, addition or removal of anti-roll bars may serve no
other purpose than that of an anti-roll bar.
3. The use of any bushing material is permitted.
4. No modification to the body, frame or other components to
accommodate anti-roll bar addition or substitution is allowed,
except for the drilling of holes for mounting bolts. Non-standard
lateral members which connect between the brackets for
the bar are not permitted.
B. Rear anti-roll (sway) bars may not be removed, replaced, or
modified in any way.
Looks like I have a few bucks to buy and advantage or two...
WeeAsp is offline
Similar Threads
Just double checking. Sarif2029 Wheels & Tires - Sponsored By Tire Rack 3 05-23-2007 09:55 AM
installing double din radio in 02 zx3 chunkitron3030 MK1 Interior Mods & Upgrades 4 12-30-2006 04:45 PM
PZEV - Why do people call their car by their emission classification ? microtonal DURATEC Performance (2003-2007) 55 05-31-2006 12:14 PM
AutoX Rules y2kpedo Autocross Racing 12 01-23-2006 04:23 PM
Custom Double DIN for LCD wholesale37 MK1 Interior Mods & Upgrades 4 05-17-2004 11:55 AM
