#21 | ||||
. Also, to keep the top line from spilling fluid all over, I lifted the line above the reservoir and let the end rest on the cowl, be careful not to bend the line too much or it will break.
Former owner 2003 Comp Orange Euro SVT then 2002 WRX Wagon, now 06 Magnum R/T, selling it to get another SVT Focus... 1979 Ford F-150 SWB 4x4 460/ZF 5 speed 1969 Dart GTS 340/4 speed |
#24 | ||||
Clutch Master cylinder line O rings
Thank you all for this thread on the leakey master cylinder! Mine just started leaking about two months ago. I live in Northern VA, and it's been really cold here, so I'm just getting around to it. I bought the new Master cylinder from the Ford dealer. The shop manual says to replace the o rings on the line connections if necessary. Did anyone have to replace theirs? If so, where did you buy them? Ford doesn't have a part number for the rings themselves, and they only come on the two lines you disconnect from the master cylinder.
Thanks, John, Alexandria, VA |
#25 | ||||
I didn't replace the o-rings. I would check to make sure there were no leaks on the firewall side as that, I think, is where they would show a problem. If you have any questions on the removal and replace feel free to PM me.
#27 | ||||
No problem. Good luck and have fun.
#28 | ||||
Thank you so much for your advice. I sucessfully replaced my clutch master cylinder last week. No more leaks! Now, does anyone have advice as to which product to use for cleaning brake fluid off of carpet? :-)
#29 | ||||
You could try the Orange Hand cleaner or some Dishwashing soap that is good at cutting grease and you might try a detail shop, sometimes thay have some "magic stuff" that will remove it.
#30 | ||||
my master cylender failed twice destroying my cluth leading to $1400 worth of repairs in teh first two years of ownership...
"Logic is a way of saying that anything which didn't happen yesterday won't happen tomorrow" - Robert Heinlein Glory Road "The question is, do you possess the constitution, the depth of faith, to go as far as is needed?" - Boondock Saints |
