"How To" - SVTF Header Wrap - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-13-2007, 12:46 AM   #1
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Talking "How To" - SVTF Header Wrap
I haven't seen this done yet, at least not in a way that looks nice.....
Header Wrap HOW-TO:
NEEDED ITEMS:
-Header Wrap (1 roll of 50'x2" is reccommended for 4-cyl engines) I had about 18" left over with that length
-Metal ties
-(optional) silicone spray sealant for wrap
-Hose Clamp(s)
TOOLS:
-2 jackstands
-Jack
-Breaker bar
-Sockets 8mm, 10mm,113mm
-PB Blaster
-Metal sheers
1. 8mm socket for header cover shield bolts (4 top, 2 bottom) (may need PB blaster to break free)(my bottom ones were already popped off the shield) re-attatch line after bolt is off
2. metal sheers to cut header heat shield
3. HAVE FUN cutting the heat shield to pieces…….
4. PB Blast the header attachment bolts and let soak
5. remove the header bolts and cat bolts…..10mm & 13mm…I loosened the header first, them went under and separated the cat and the header. Breaker bar for cat bolts. My cat bolts are not stick size.
6. pull out dipstick, it pills out
7. remove header from engine…I took it out from below.
8. Replace dipstick and cover manifold holes to keep dirt out.
9. OPTIONAL……I painted the top of the header with the HI temp Silicone paint to make it have a finished look….
10. Wrap the header…….Took me over an hour…have fun I used a hose clamp at the bottom of the header for the last part of the wrap to secure the two pieces together. I will check on that and see how it holds up to the heat.
11. Seal the wrap by painting with Hi-Temp silicone paint……it says that curing happens at 400 Deg. I will be curing mine by installing and running my car….I do not have an oven available…..3 coats seemed like enough.
12. install the header making sure not to smear the paint if you did not bake the header. Install is the reverse of removal.
13. install the dipstick
14. check all bolts for tightness once again
15. start car, and let it cook off all the header wrap residue and paint…it WILL SMOKE a LOT. As in tremendous amounts of SMOKE.....
16. I have driven the car for a day, and it has stopped smoking, but it smells from time to time like it’s burning off. I can now touch the headers without burning my hand. Under hood temps have def been reduced.
the car still smells a lil bit, and it has been a few days now......it baked on nicely though.
PICTS:
Supplies:
Nice, shiney header heat shield:
bolt removed to allow repositioning of P.S. line (so I wouldn't cut it with the shield):
bending shield to remove:
Metal sheers:
underside......need to cut here:
Popping the rivets off the sides of the shield.......almost there....
it's OFF!!!!! and it looks hideously ugly....
well, it's in one piece.....save it for the collection....
remove header from cat and engine block........pretty simple....
wrapping the header......have fun, it takes a bit....I had about 18in left over when I was finished....
showing the amount of overlap I used.....
I did it in this order:
I had to cut the one area by the lower bolt to get the wrap to lay flatter on the header....
That is the header wrapped.....next I silicone painted it to seal it.....
I did 3 coats:
1-2 coats:
finished.....it's almost a powder, so you have to be carefull not to smudge the paint....I held it by the wrap......
nice and pretty.....
next I reinstalled it....and this is the result
view from below:
so...HOW MUCH does it smoke??????
like THIS for 10 min.......
It took me 5-6 hours, taking my time, not messing up, doing it correctly.......
have fun
HaveBlue83 is offline
Old 02-13-2007, 04:06 AM   #2
Moe-van1
Moe-van1's Avatar
Fan#: 46
What I Drive: SVT
FF Reputation: 1 Moe-van1 Good Standing Member
looks great but, I heard that your header can rust faster with it in that condition if you wrap them up?..
I am really tempted to do this considering my heatshield has been off for some time
2002 Sonic Blue SVTF
BASELINE DYNO WHP 157, TQ 144ftlbs
[color=orange-red]DYNO SHEET "Click Me!!"[/color]
Moe-van1 is offline
Old 02-13-2007, 07:47 AM   #3
CrazySVT
CrazySVT's Avatar
Fan#: 25421
What I Drive: 2002 Silver SVT boosted crew #95
FF Reputation: 1 CrazySVT Good Standing Member
Buy-Sell-Trade Rating: (7)
yeah i'm doing that this spring...cant wait clean the motor and then the header wrap
02 svt turbo ...R.I.P
2013 vw tiguan 4motion se 2.0t
2013 Toyota carolla S
CrazySVT is offline
Old 02-13-2007, 08:59 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,548, Level 100
Points: 52,548, Level: 100 Points: 52,548, Level: 100 Points: 52,548, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
If you will put the wrap into water about 10 min before use you will find it will wrap a lot tighter and easier to use
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 02-13-2007, 09:09 AM   #5
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
the water method does simplify the install as well as taking about half the time. when i wrapped mine, first i grinded the shield mounts off. it looks waay cleaner. take a look in my gallery. i am going to redo mine when warmer weather hits. though, this time i am getting the black wrap. ihave my orp wrapped as well, but no pics sorry.
scrammer is offline
Old 02-13-2007, 09:17 AM   #6
xmillsx
xmillsx's Avatar
Fan#: 29100
What I Drive: 2005 silver ion redline
Points 294, Level 5
Points: 294, Level: 5 Points: 294, Level: 5 Points: 294, Level: 5
Level Up 88% Completed
FF Reputation: 1 xmillsx Good Standing Member
wow i have to say im impressed, that looks really good. ill most likely be taking that route in the spring.
no one is born straight edge its a choice. you dont just wake up one day and say, you know i think im gonna be straight edge.
true till death doesnt mean anything till your dead.
Mods soon to come: JRSC and some tranny goodies
xmillsx is offline
Old 02-13-2007, 12:21 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Nice write up!
Keep the extra hints coming as well folks, like the soaking the wrap in water comment.
So, what color did the silicone paint turn after it got heated up?
Man, that was a lot of smoke!
WD40 is offline
Old 02-13-2007, 12:23 PM   #8
03cdfsvt
03cdfsvt's Avatar
Fan#: 40429
What I Drive: 2002 Escort ZX2
FF Reputation: 1 03cdfsvt Good Standing Member
Does header wrap really help or no?
03cdfsvt is offline
Old 02-13-2007, 12:28 PM   #9
svtguy21
svtguy21's Avatar
Fan#: 32290
What I Drive: ford focus svt 5 door
FF Reputation: 1 svtguy21 Good Standing Member
well i can put it this way after i removed the heat sheild i couldn't even touch the header(why would i try>because i did), after the heat wrap i could place a finger on it(yes i tried it again) i held in the heat enough for me to put my finger on it
So i'm driving a new mazdaspeed3, what?
13.8 1/4 mile at 109.7 mph w/ my former svt focus
Proud member of Focal Point
svtguy21 is offline
Old 02-13-2007, 12:32 PM   #10
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
That is one thing i agree with Tom on, you need to soak each piece in warm water before you wrap the header. It will wrap alot tighter and conform smoother. Very good write up though. It will steam for a good 20 mins after youre done.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Similar Threads
Another Header question; Shorty vs Race DueceCoupe ZETEC Performance (2000-2004) 43 02-25-2007 07:45 PM
HEADER.. again!! SinCityZX3 ZETEC Performance (2000-2004) 9 08-17-2005 12:20 AM
SVT header vs. Race header? l88m22vette ZETEC Performance (2000-2004) 1 08-22-2004 01:46 PM
header wrap 2000kona ZETEC Performance (2000-2004) 16 08-07-2004 06:14 PM
Exhaust Header Heat Wrap navy_ma04 ZETEC Performance (2000-2004) 30 05-06-2004 02:05 PM
