:: Cracked Thermostat Housing Assembly :: - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2006, 08:23 PM   #1
..:: sleestak ::..
on thin air
..:: sleestak ::..'s Avatar
Fan#: 22528
What I Drive: 04 Forester XTi
Points 14,710, Level 78
Points: 14,710, Level: 78 Points: 14,710, Level: 78 Points: 14,710, Level: 78
Level Up 65% Completed
FF Reputation: 80 ..:: sleestak ::.. Excellent Standing Member
Buy-Sell-Trade Rating: (15)
I have seen a few threads about this but no pics...In short, our notoriously leaky valve cover gaskets seep oil and it gets between the block and Thermostat Housing this causes the Oring to swell and sometimes crack the plastic.
Just thought I would show you a pic of what that is exactly...I just dealt with this today...good thing I bought the housing assembly as well.
As you can see the one on the left is the bad one. The ring swelled and did crack the pastic that surrounded it.
The repair went really easy. Just drain the coolant, unhook the hoses and take three bolts outta the side of the housing to remove it from the side of the block.
On the front of it is another plastic piece held in place with three screws (and some mysterious chunk of metal on two of them). Just unscrew them and pop it off...you will find your thermostat inside:
You will need to swap that over to your other housing, but check to make sure the rubber seal around it is in good shape. You might just want to go ahead and replace it while you are at it...its pretty cheap but you will have to buy the thermostat and rubber gasket around the edge seperately. ALSO, be sure to pay attention to the little air vent hole in the top of the thermostat and its position as its seated within the housing. You basically want it at the top, so it can let air breathe out.
Two other things you are going to want to swap/check are the sensor in the top:
and the ridiculous plug on the bottom:
As you can see they have little metal clips which hold them in place. Just grab it with a pair of needle nose and pull it off, then you can pull the part from the housing.
**Note** I pulled my silver "plug" and put it into the new housing...the Oring on it was crapped out and when I started my car, it began to leak. So you may want to look into getting one as backup as well as a new sensor. They both have Orings on them that could easily get toasted by the heat and chemicals. In the dealers exploded diagram, it showed a second sensor going to where the plug was, I am guessing that they use this housing on other cars and just plugged that hole up. Just keep it in mind and use the part number I listed below if you need to replace it.
All in all, super easy to do. Should take you about an hour and a half....basic blot off/bolt on operation.
Hope this helps some of you if you are thinking about doing the repair yourself. Its simple and cheaper than letting the dealer do it.
**UPDATE** Here are some part numbers for you (SVT)
Thermostat Housing Assembly - XS7Z-8592-AD (roughly 68 bucks and it includes a rubber gasket)
Sender Asy (sensor on top of assembly) - XS6Z-12A648-CA ($19)
Silver Plug - 2M5Z-12A648-AA ($15)
Thermostat- F8RZ-8575CA ($10)
..:: sleestak ::..
"Our mother of blessed accelleration, dont fail us now!" -- Elwood Blues
..:: sleestak ::.. is offline
Old 07-10-2006, 12:42 AM   #2
PizZel
PizZel's Avatar
Fan#: 488
What I Drive: Turbo'd 03 CD Silver SVT
FF Reputation: 1 PizZel Good Standing Member
good wright up, maybe someone should make this a "sticky".
205whp 179tq @ 7psi
"Always do sober what you said you‘d do drunk. That will teach you to keep your mouth shut."
PizZel is offline
Old 07-10-2006, 12:58 AM   #3
MISVTfocus
MISVTfocus's Avatar
Fan#: 13841
What I Drive: 08 Fusion SEL, Focus ST on order
FF Reputation: 1 MISVTfocus Good Standing Member
PM WD on this one he'll add it to his "SVT specific repair thread" I assume.
Good write up, mine hasn't kicked yet but if it does thanks!
Oh yeah!
MISVTfocus is offline
Old 07-10-2006, 12:58 AM   #4
likwhoa
Fan#: 33621
What I Drive: 2002 silver svt
FF Reputation: 2 likwhoa Good Standing Member
did u also put a new Thermostat in andhow many o rings r there. I think mine is broken too
likwhoa is offline
Old 07-10-2006, 01:31 AM   #5
..:: sleestak ::..
on thin air
Fan#: 22528
there is an Oring on the housing itself, that seals off between the housing and the block.
there is a rubber seal on that silver plug looking piece and also on the sensor....and one other that goes around the outside edge of the thermostat.
Thermostat is like 10 or 12 bucks, I believe.....I have to replace that seal on the silver plug piece tomorrow. I will update the post with more info as I get it on prices and part names/numbers.
..:: sleestak ::..
Old 07-10-2006, 02:20 AM   #6
likwhoa
Fan#: 33621
thanks for the info
likwhoa is offline
Old 07-10-2006, 04:53 PM   #7
..:: sleestak ::..
on thin air
Fan#: 22528
** Updated ** added list of part numbers for some of the parts
..:: sleestak ::..
Old 07-10-2006, 11:22 PM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Thanks for the info!
One thing I'd like to confirm is if these are the same part numbers for the standard ZETEC.
I think so...
It's my understanding that there's no difference between the housing, thermostat, or related parts.
^^^But, if that can be confirmed, I'm sure we'd all rest easier.
Moved to ”Ford Focus Technical Chat”
WD40 is offline
Old 08-11-2006, 09:35 AM   #9
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
I think so...
I don't think they are the same. I'm getting ready to repair my girlfriend's 00 Zetec, and while researching this, it appears the standard Zetec housing is different from the SVT housing. The biggest thing to note is the Zetec doesn't have that silver plug.
Egz is offline
