Focus Fanatics
Focus Fanatics (http://www.focusfanatics.com/forum/index.php)
-   Central Florida Motorsports (http://www.focusfanatics.com/forum/forumdisplay.php?f=82)
-   -   PRODUCT FAQ: Duratec / Zetec / SPI Lower Engine Torque Mount (http://www.focusfanatics.com/forum/showthread.php?t=96088)
CFM Focus 08-27-2006 01:23 PM
http://focus.c-f-m.com/ProductImages/cfm_6-0010l.jpg
Click image above to view more information or purchase product
Here you will find all information relevant to this product. Please only post questions or information that will be useful to others who own or are considering purchasing this product. Thanks!
scyzzo17 08-29-2006 08:15 PM
I received your mount this afternoon and I'm still trying to get it on. I took off the bracket thats was on the transmission and it looks like a botton or something block the mount. Its a hollow metal cylinder in which the bolt goes threw. Its at an angle how do i fix this? Wedged in there really good.
CFM Focus 08-29-2006 09:08 PM
Please give more detail or send pics. Not sure I understand what is going on...
scyzzo17 08-29-2006 09:49 PM
i don't have a digital camera but i'll try to explain. The end of the mount that connects to the transmission. It will not fit. I took off the bracket, it had three bolts two parallel and one perpendicular. The bolt goes through the bracket then the mount then the threaded side of the bracket. On the unthreaded side of the bracket there's a cyclinder in a hole in the bracket. The cyclinder has a hole in it for the bolt to go thrrought. THAT cyclinder is pushed in and wedge at an angle so I cannot move it. I'm not sure what its called but I want to say it a bushing.
This is a zetec by the way.
scyzzo17 08-29-2006 10:19 PM
1 Attachment(s)
Circled This is where the bushing i'm refering to is located.
scyzzo17 08-30-2006 11:19 AM
I ordered a bracket from ford today and should get it tuesday I'll let you know ghow it goes.
CFM Focus 08-30-2006 12:04 PM
Was your bracket damaged for some reason? What part number did you order. I had to order three brackets before I got the correct one.
scyzzo17 08-30-2006 07:07 PM
The sleeve inside the bracket was messed up so I'm getting a new one. I watched it up with the picture they showed me on their computer so I'm pretty sure its the right one.
scyzzo17 09-05-2006 12:28 PM
You were right the picture didnt match up with the correct part number so I'll have to look for one.
Could you give me the correct part number to order?
scyzzo17 09-08-2006 07:23 PM
OK I just got the bracket from you guys today and installed right after I got home from work. It took a lot of work to get it all together but it was worth it. Its so much easier to shift now and it doesn't clunk anymore after you downshift and coast around a corner then accelerate again. I love this mount, its well worth the money but I can't compare it to the VF since never driven a focus with their mount. And thanks to CFM for helping me through this special case. And by the way I think my subframe is bent a little I'm not sure but it might be to me jacking up the car up at the lower engine mount so I recommend that people don't do that anymore, two jacks won't hurt it's easier to prevent than to cure.
http://www.focusfanatics.com/aboutus/copyright.asp
