Focus Fanatics
Focus Fanatics (http://www.focusfanatics.com/forum/index.php)
-   General Technical Chat (http://www.focusfanatics.com/forum/forumdisplay.php?f=47)
-   -   Timing pin and bar measurements? (http://www.focusfanatics.com/forum/showthread.php?t=312248)
Deus Machina 03-19-2013 11:20 PM
Sorry for the separate thread, but it wouldn't be seen in the other one. My timing belt snapped, I'll need the tools.
Anyone have ones they can measure? Thread size, length, and diameter of the pin, and dimensions of the bar?
I'll have a touch time scraping together money for the timing kit, let alone special tools, but I do have a lathe and mill in the garage. I could cut the appropriate bolt down to size.
RallieConGoggle 03-20-2013 07:22 AM
http://www.focusfanatics.com/forum/s...ght=timing+pin
I would sell you mine if you can wait on shipping.
RallieConGoggle 03-20-2013 07:23 AM
Also, here's my how-to with some pics of the tools I bought.
http://www.focusfanatics.com/forum/s...78#post2732278
Deus Machina 03-20-2013 07:27 AM
I've been reading through the how-to already. Good stuff. :)
I can't really wait, though. The car's in a parking lot of a building that is, thankfully, under renovation, but I doubt the owners want it there long.
I can manage this sort of thing with a screwdriver or the like if need by, but I'm well aware it will suck hard.
RallieConGoggle 03-20-2013 07:34 AM
The hole is kind of behind the CAT, so a screwdriver would be tricky.
http://adamjohncharles.com/timingbelt/IM000151.JPG
http://adamjohncharles.com/timingbelt/IM000153.JPG
sailor 03-20-2013 09:20 AM
FWIW I think he means doing it by using the screwdriver down the plug hole to find TDC, wouldn't work to use one down the timing pin hole......
It's not like sticking a dial indicator down there, but you might be surprised how close you can get to exact TDC that way. Even with a dial indicator it takes a bit of back & forth wiggling to find the "center" of the piston's "dwell" at TDC. Fingers work quite well at feeling for the right spot.
If you need to do a "quick & dirty" belt replacement, where you leave the adjustable cam gears alone & just slide the belt on once you get the basic timing position for the crank & cams set up, the "screwdriver method" is adequate to get the cogs in the right notch & get the thing running!
Older engines weren't timed any better than the closest notch, and anyone who's done one of those would know how to get the Zetec timed that well.... Once the cam gears get their initial "set" at the factory, unless the engine has been rebuilt timing variations from a different belt will be minor. Nice to get it 'exact", but it should run fine with the original adjustment left alone. In fact, the "cam bar" is only NEEDED when you are resetting the cam gears since you can eyeball the cam position by the notches for the bar close enough to get the new belt in the right notch on the gear.
Certainly not as easy as when everything is locked in the right position, but certainly "doable".
Cheers!
amc49 03-21-2013 06:31 AM
Amen brother. Loosening sprockets is what causes all the trouble, once you do then you can have partial tooth errors all over the place. Not loosening sprockets means you can only have full tooth errors which are much easier to see. The Ford procedure sets up the mechanic to have much more trouble to me. Then VCT confuses the issue even more.
The entire idea of the camtool is to get you merely right back where you were before you loosened sprockets to begin with. Silly.
If the timing belt teeth spacing was truly off virtually at all the maker would be out of business overnight. Those teeth have to be CLOSE to run at all well.
RallieConGoggle 03-21-2013 06:42 AM
Mine didn't line up perfectly with the bar, but I didn't bother adjusting the sprocket. I think that my intake is just a hair retarded now.
jasonbi 03-21-2013 09:48 AM
if your hard up for the funds...use a metal file to lock the cam. thats how i did mine...came out perfect!
1turbofocus 03-21-2013 02:05 PM
You dont need to buy the tools , I have built hundreds of Zetec engines and or heads and never used them
I use a file in the cams or you can get a flat bar and cut it from home depo and a screw driver in the #1 piston hole , get TDC and bar in and your good to go , your going to get a s close with this as with the tools , trick is to make 100% sure your at TDC
If your 100% TDC you will SLIGHTLY turn the engine each way and the screwdriver wont move , lock the came , install the best
http://www.focusfanatics.com/aboutus/copyright.asp
