-   Wheels & Tires (http://www.focusfanatics.com/forum/forumdisplay.php?f=50)
-   -   xxr 530 +35 mounted on 2012 hatch (http://www.focusfanatics.com/forum/showthread.php?t=302574)
adamturbo 11-18-2012 07:09 PM
18x 8.75, +35 :here you go i would assume that this is a first. i have machined my xxr wheels to mount to the 2012 focus bolt pattern. i also got new nuts that will work for my system. i have used a +35 offset and it looks good. i am running stock ride height so rubbage wont be an issue with 225 tires, these will sit perfectly flush to the car.
heres a pic of the new nuts and washers
http://i64.photobucket.com/albums/h1...t/PICT5367.jpg
heres the modded wheel. i machined the hole to be a snug fit to the new lug nuts and will use hub centeric rings for safety
http://i64.photobucket.com/albums/h1...t/PICT5366.jpg
UPDATE: done and mounted.
+35 offset is so perfect
http://i64.photobucket.com/albums/h1...t/P1050209.jpg
http://i64.photobucket.com/albums/h1...t/P1050210.jpg
http://i64.photobucket.com/albums/h1...t/P1050211.jpg
http://i64.photobucket.com/albums/h1...t/P1050216.jpg
Ox-y-GenIII 11-18-2012 09:57 PM
Nice wheels. And they will look great being so flush. Which tires you putting on them?
Indy'sexclusiveZx3 11-18-2012 10:05 PM
You have balls for changing the mounting surface of your lug nuts, why not get wheels that actually fit
Michael Jackson 11-19-2012 01:11 AM
Nice. Can't wait to see this.
Sent from my SCH-I905 using FF Mobile
adamturbo 11-19-2012 01:23 AM
i run my own machine and fab shop have built many race cars. these are not the first wheels i have modded in this way, our datsun rally car needed a similar mod and has had no issuse under the abuse of rally racing. so i am very confident that the strength is more than sufficient. besides i had these wheels i was going to use them on my evo but i ended up selling that car so the wheels needed a good home.
as for tires im running achilles atr sport 225 40 18. i ran these tires on my evo with great results, they are quite sticky and have excelent wet and dry traction.
Nickgt40 11-19-2012 02:29 AM
Umm... I wish you the best, I really do. But those oblong holes aren't what I would call confidence inspiring. You better do all you can to get those wheels hub centric because I don't see this ending very well.
adamturbo 11-19-2012 07:18 PM
i have tight hub centric rings all machined up, the lug nuts themselves are a snug fit to the hole in the wheels. this really isnt as bad as you think it is. i do have experience with this all tolerances are to the thousandth of an inch.
drunkyoda 11-19-2012 07:23 PM
i don't care what anyone says these wheels will look good on there. also i am assuming you machined better quality wheels before...
|Heath_Bar| 11-19-2012 07:33 PM
cant wait to see a whole car pic
Michael Jackson 11-22-2012 06:40 PM
Piiiiiiiiiiiiiccccccccctttuuuurrrreeessssssss?
