-   SVT Performance (2002-2004) (http://www.focusfanatics.com/forum/forumdisplay.php?f=40)
-   -   CEL codes P0172 and P0325 (http://www.focusfanatics.com/forum/showthread.php?t=299387)
SCTSVT 10-08-2012 08:23 PM
I just replaced the coil and wires in my SVT and after running absolutely perfect for about 60 miles the CEL came back on. I know they're codes for running rich and a knock, but after changing the Knock sensor back in July that code went away. Is it already bad again?! Any input would be greatly appreciated
Steve
jp96921 10-17-2012 10:43 PM
Hi Steve! you need to check to see if you have a vacuum leak in and around the engine. having a vacuum leak will cause P0172 and possibly the spark knock on accel. hope that helps.
SCTSVT 10-22-2012 04:35 PM
Thanks! Where would the vacuum lines be? I know there's one by the firewall, but are there more?
