-   Archive (http://www.focusfanatics.com/forum/forumdisplay.php?f=103)
-   -   NEED 08-11 headlight adjuster (http://www.focusfanatics.com/forum/showthread.php?t=299170)
A7xschecter6661 10-05-2012 11:58 PM
If anyone has focuses in their local junk yard feel free to go pull one out and I will pay you.
They twist out one way like a bulb socket and then you have to pull the rod with the ball socket on it out
This piece pushes in and turns like a bulb socket. It has a screw attached to it with a ball on the end which pops into the joint located on the back of the reflector inside of the headlight.
I did my projector retrofit today, everything went perfect except I broke one, so my lights are too low!
This is the piece here, slides in and twists
http://i1190.photobucket.com/albums/.../WP_000969.jpg
If you have a focus at a local junk yard help me out, car is currently undriveable at night
A7xschecter6661 10-06-2012 06:58 PM
Or if anyone knows the part # or where to find it, that can help.
The only thing I can find is here
http://www.fordpartsgiant.com/partli...-21464862.html
708942-S439
Other diagrams I found, it looks like it's only part of the assembly :(
Also if anyone has focuses in their local junk yard feel free to go pull one out and I will pay you.
A7xschecter6661 10-07-2012 05:53 PM
Just found a guy selling a focus headlight, what do you know the adjuster was broken! FML
cmmike1 10-08-2012 07:39 PM
i have an extra junk light i'll see if i can remove it. have any advice so it doesn't break? does the lens need to be separated to remove it?
A7xschecter6661 10-08-2012 08:23 PM
I will pm you
