Focus Fanatics
Focus Fanatics (http://www.focusfanatics.com/forum/index.php)
-   SVT Performance (2002-2004) (http://www.focusfanatics.com/forum/forumdisplay.php?f=40)
-   -   Replacing front brakes on my 04 svtf (http://www.focusfanatics.com/forum/showthread.php?t=298251)
kennysvt 09-23-2012 08:05 AM
I need some help
macdiesel 09-23-2012 08:09 AM
You need help, like you have never done brakes before help? Might want to check out YouTube tutorials. Not hard if you have tools.
kennysvt 09-23-2012 08:10 AM
I have done brakes they say not to remove the spring what r they talking about
BigRed03 09-23-2012 09:44 AM
look at the caliper, there is a sort of leaf spring type thing. it is a pain to get back on LOL
kennysvt 09-23-2012 10:02 AM
So they can be replaced without removing that ?
macdiesel 09-23-2012 11:48 AM
You can use vice grips to put the spring back in place easy.
kennysvt 09-23-2012 11:55 AM
Ok thank u now 3 of the 4 caliper bolts r striped go figure
BigRed03 09-23-2012 02:04 PM
then you need to teach me the trick, it always takes me 10 minutes to get it back in using a needle nose
what bolts are you talking about? the 6mm allen key attaching caliper to bracket, or the ones from the caliper brackets to knuckle???
kennysvt 09-23-2012 02:16 PM
The ones holding the caliper so I can't get em off and no will have to go to ford and get new ones
z28forlife 09-23-2012 02:28 PM
Really, I got the clip back on in under 30seconds. Its straight forward, pretty easy brakes IMO.
http://www.focusfanatics.com/aboutus/copyright.asp
