Focus Fanatics
Focus Fanatics (http://www.focusfanatics.com/forum/index.php)
-   General Technical Chat (http://www.focusfanatics.com/forum/forumdisplay.php?f=47)
-   -   Help with identifying small hose (http://www.focusfanatics.com/forum/showthread.php?t=297542)
glenbailey511 09-12-2012 05:49 PM
Could someone please help me identify the small hose indicated in this image? I have a 2003 Ford Focus ZX3 with Zetec engine. I found this image on Focus Fanatics, it is not my car, but I have the same hose. It's leaking coolant but I can't find it in my Haynes book.
Thanks!
Glen
https://dl.dropbox.com/u/32872845/Focus%20hose.jpg
PumkinSvt 09-12-2012 05:55 PM
pcv valve
PumkinSvt 09-12-2012 05:56 PM
and it shouldn't be leaking coolant I think you mean oil.
TerryB 09-12-2012 05:57 PM
I think he's looking for the small elbow above the PCV valve. I've been looking myself.
glenbailey511 09-12-2012 06:02 PM
Yes, TerryB - looking for the elbow above the valve. It's coolant that is leaking, not oil. And it LOOKS like it's coming from where this is connected. Maybe coolant is leaking/dripping onto it? Definitely looks like it's leaking right at the connection though.
glenbailey511 09-12-2012 06:05 PM
Here's another picture I found with a little better view, though the picture is smaller.
https://dl.dropbox.com/u/32872845/fo...ine%20GOOD.jpg
TerryB 09-12-2012 06:21 PM
You most likely have a thermostat housing leak. Try a search on that.
oshoguno 09-12-2012 10:24 PM
Yes, thermostat housing leak. I had the exact same issue. If you can get it up on a hoist and look at it from the bottom you will see the trail.
http://www.focusfanatics.com/aboutus/copyright.asp
