-   Wheels & Tires (http://www.focusfanatics.com/forum/forumdisplay.php?f=50)
-   -   rear tires wearing (http://www.focusfanatics.com/forum/showthread.php?t=295429)
red421 08-16-2012 11:22 AM
rear tires wearing
i just bought my 00 zx3 a couple weeks ago and the inside on my back tires are wearing like crazy, im not 100% on what the problem is?
i read somewhere that there is a recall on the upper rear control arms but when i try searching it on google it seems like im not getting anywhere. is ford still responsible for this even though its 2012? has to be some kind of recall experation if there is actually a recall.
if i do replace the control arms myself whats it going to do to the alignment of the back wheels? will it be right or is it going to need adjustment?
bbcobra 08-16-2012 11:36 AM
first thing to do is get the alignment checked. improper toe will wear the rear tires on the inside in a hurry.
ImmortalMort 08-16-2012 12:23 PM
There are round adjusters for your rear control arms, that your springs are seated on. If your bushings aren't seized on, you should be able to turn them to change the length the arms stick out the side of the vehicle. Also, your springs could be wore out & sagging if they haven't been replaced recently
Mr.Bergner 08-16-2012 02:13 PM
MOVED TO: Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
BLRich1 08-16-2012 02:51 PM
This.
rear toe should be set to near 0. "with in spec" is still too far our in many cases.
thenorm 08-16-2012 05:56 PM
+1
toe is out of spec.
Geezer 08-16-2012 06:08 PM
There's lots and lots of threads regarding this issue. A quick search would have revealed all the solutions.
Yes, the focus rear end is very tempermental regarding proper rear alignment. The problem is that the Focus was often delivered from the factory with lots of rear camber (albeit within Ford specs). The rear toe range is also pretty broad. The ideal rear settings are no more than -1.5 degrees of rear camber and 0.04 inches of rear toe-in (especially if the car is lowered). Rear camber is not adjustable. You will need to get an aftermarket adjustment devise such as camber bolts or adjustable upper or lower control arms. Camber bolts are the cheapest and work just fine for most cars.
Yes, Ford did have a service campaign years ago. They would replace the upper control arm to reduce negative camber. The problem is that your car had to be outside Ford's recommended spec range (which was already way to broad and is what caused all the problems in the first place) so very few if any people qualified for the replacement control arms.
car+guy 09-06-2012 02:00 PM
Solution to rear tire inside edge wear on Ford Focus all models, all years:
The primary reason is too much negative camber for too little weight. This causes the tires to travel on the inside edges rather than on the tread surface. The most typical “solution” offered by Ford and Tire Retailers is to “rotate more frequently”, but this just wears 4 edges rather than 2 when alignment is within spec. Ford did not make camber setting adjustable, so you have to modify a suspension component, the upper control arm to hub connection point. Ford will not do this for you.
Purchase an aftermarket “camber bolt” set; <$35. I used the Specialty Products Company part number 81310. I think this is the most common and found at local auto parts retailers, and on the internet. The following instructions are for this bolt, to remove “negative camber”; i.e. make the wheel perpendicular to the ground (or almost).
The kit comes with 2 bolts, each with 2 “washers”, and nuts. The bolt is installed in the upper control arm where it joins with the hub, one on each side of the car. The installation is as follows:
1. Set the parking brake. Break the lug nuts free on rear wheels. Block (chock) the front wheels.
2. Jack up the rear of the car, and support with floor jack stands. I placed stands under lower control arm bracket.
3. Remove the rear wheels
4. Remove the bolt from the upper control arm at the hub. (Repeat these steps on the other side of the car)
5. The weld nut is still on the hub frame, and must be removed. This is the only tricky part, so take your time. I used a “Dremel tool” with a cut-off wheel. I had a 90 degree drive on the dremel tool as it improved control, and allowed easier access. Wear safety glasses. The weld nuts have 3 points where they are welded, as seen by imprints on the collar of the nut. The object is to cut only 1 weld free. Cut where the weld nut joins the hub, in effect, sliding the cut-off wheel between the hub frame and the weld nut edge. After making as deep a groove as possible without getting close to the brake line (be careful); use a hacksaw. Remove the blade from the hacksaw and reassemble in place with the blade below the brake line and hacksaw frame above the brake line. Take your time and saw carefully between the weld nut and hub frame. Eliminating 1 weld spot and making a grove is the objective. When you have sawn as much as possible, remove the hacksaw. Take a small cold chisel that fits down into the grove, and give it a whack. The cold chisel acts as a wedge to separate the parts (objective is side-ways pressure). The other 2 weld spots will pop loose. Weld nut gone, “hard part” done.
6. With the dremel tool cut a notch on the top edge of bolt head, aligned with the high-cam lobe on the bolt shaft, so you know where high-cam is after installation (Also, in the future ,to make sure it has’nt moved for some reason).
7. Coat the bolt shaft and cam with anti-seize lubricant. Leaving the “washer” on the bolt, with the big tab pointing out, install the bolt. Make sure the little tab on the washer fits into the hole on the hub frame (this is the adjustment mechanism). The cam on the bolt now sits inside the upper control arm bolt hole.
8. Install the other washer (big tab out, little tab in hub frame bolt hole) and nut. Thread on the nut until the little tabs cannot escape from the hub bolt holes (snug but not tight). Positioning adjustments are ready to be made to reduce negative camber.
9. Rotate the bolt head until the notch you made (high-cam) points to the center of the car (away from you). Keep it in this position while doing the next 2 steps.
10. Rotate both washers’ big tabs by tapping with a pin-punch and hammer. Take your time. The little tab has to stay inside the hub frame bolt hole. Be careful of brake line and brake bleeder valve. If the big tabs are toward the center of the car (away from you on the back side of the bolt), the hub frame hole has been extended to its maximum outward position (via the little tab). In effect the control arm has been “lengthened”, making the hub more vertical.
11. Tighten the bolt. Hold the bolt head, so cam position does not change, and tighten nut. You’re done.
Now would you like to know what the new camber setting is? If yes, here’s a “shade-tree mechanic’s” way of checking. If done properly I bet it’s more accurate than a 4 wheel alignment for $80.
1. Take the car around the block to allow everything to “settle in”.
2. Park the car on level ground. (My garage cement floor is perfect)
3. Take a 2-foot carpenter’s level (plumb-bob string?) . Stand it on-end next to the wheel. Make sure the bubble, perpendicular to wheel, shows it is absolutely vertical. Holding in vertical position, on the center-line of the wheel, measure the distance to the bottom edge of the wheel; measure the distance to the top edge of the wheel. The wheel edge may have some surface contours so position the car so the same contour on top and bottom align vertically through the center-line of the wheel. There should be some measurable difference. In my case, the top distance measured 1/8” greater than the bottom on each rear wheel. I have 16” wheels, so multiplying each by 8 gave a ratio of 1:128. The question is what degree of negative camber does this represent?
4. I’m terrible at math, so I went to the web… http://www.1728.org/gradient.htm Select “RATIO”.
Enter “Input rise” = 1; Input run = 128. Select “Calculate”. My car now has a negative camber of .447 degree. For the 2009 Focus the range is 0.0 – 2.0 according to local alignment shop.
If the results are “not enough negative camber”, loosen the bolts and tap the washers around until correct degree is achieved. To my knowledge it is not required both rear wheels have exactly the same camber (shops only seem to care that each is within range). If you would like to know how successful this process is, you could perform this same measurement before starting the job; allowing comparison of before and after.
There are many considerations for the desired amount of negative camber including weight typically carried in the rear, aggressiveness of driving, etc. The internet is full of good articles.
If the inside edge of the tire is not only wearing but also “cupping” (also called “feathering”); then worn suspension parts may be the cause. Most common is the shock absorber. My opinion is, with an entry level vehicle, Ford did not spend too much on the rear shocks. These are easily changed to an aftermarket product with more responsive characteristics. But, removing negative camber will always help as the entire tread surface is now in contact with the road, not just the inside edge.
If this method did not provide enough correction, there is a more expensive alternative. Moog offers an adjustable upper control arm replacement; approximately $275 for the pair. These are usually used when the car is “lowered”. I have not tried these, as it was not necessary in my case. Frankly, I think maybe this is used to shorten the control arm, not lengthen it, so I’m not sure if this is a solution for a “stock” Focus.
It takes a long time to describe, but I can do the entire job in < 2 hours. The first time it took >4 hours because I was figuring out all the stuff I just described. In my case, visually from the rear, confirms the tires are now vertical, compared to “before” when they looked slanted to the inside… like this / \ (well, not quite THAT bad).
Hmmm…I wonder if I turned the washers so big tabs were in opposite directions (1 in, 1 out), could toe-in be changed? Not that I would, but interesting thought. Seems knowledge just raises more questions.
Good Luck,
Brian Ebels – bpebels@comcast.net. If you would like a Word Doc send me an email.
thenorm 09-06-2012 03:02 PM
wall of text Crits you for 999,999,999 dmg.
game over.
