-   ZETEC Performance (2000-2004) (http://www.focusfanatics.com/forum/forumdisplay.php?f=39)
-   -   Cam gear question (http://www.focusfanatics.com/forum/showthread.php?t=2776)
Solaris 11-06-2003 10:21 AM
Cam gear question
i'm looking to cam gears and i would like to know if i get cam gears and get them tuned if i'll get hp increase with using stock cams. I don't want to get stage 2 cams cause well i want my to idle and what not.
EnigmaZV 11-06-2003 10:53 AM
How much you gain, if anything at all, depends on how well your stock cams were tuned from the factory. You may see a lot, you may see nothing. You can always go with a set of stage 1 cams, or get a chip to raise your idle to accomodate stage 2 cams.
TORQUERULES 11-06-2003 11:44 AM
The idle on our cars is too low from the factory anyway. Since our stock gears and cams have no key or pin to properly position the gears, it is just sheer luck if you have factory cams that are anywhere close to optimal, or even at 0 degrees!
Solaris 11-06-2003 11:49 AM
if i get stage 1 it's just an intake cam right?
jetbill 11-06-2003 07:09 PM
stage 1 are both from crane, i love'm i got them from extrememobileperfomance.com, here is a link to crane cams on ebay where i bought mine.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2441627745
ALL_MOTOR_ZETEC 11-06-2003 08:38 PM
If you get cam gears and keep your stock camshafts, after you get your cam gears tuned you will see a increase in H.P. and torque.
Solaris 11-06-2003 10:39 PM
kk thanks
EuroZX3 11-06-2003 10:47 PM
i think matt sum'd it up well. u should almost always see a gain from dyno tuning them, theres a very slim chance they will come from the factory making the most power...
stage 1s are nice for low end but u might be hungry for some top end later.
Solaris 11-06-2003 10:53 PM
we will see i'm jusy curious i have no plans to get cams or gears. I still have to finish my exhaust and then spend almost 2k on suspension, tires, wheels, and brakes. so for me on thign at a time
