-   General Technical Chat (http://www.focusfanatics.com/forum/forumdisplay.php?f=47)
-   -   Fuses (http://www.focusfanatics.com/forum/showthread.php?t=21861)
Epox 08-10-2004 05:40 PM
Fuses
For some reason the 7.5 amp fuse that controls the gauge cluster and the remote turn on wire for the radio and amps blows when i turn my key to start my engine. I dont think that it is my stereo b/c ive had it in there sence the 2nd day ive had my car ive had it for 2 months now and it just started doing this today[???:)] Please help
S2 08-10-2004 07:56 PM
Do you have an aftermarket stereo? Chances are that you are shorting out somewhere causing the fuse to blow. Check the wiring or the HU and the remote wire for the amps, etc. Maybe the rubber around the wire had gotten worn off at a sharp angle where the wire is run. Something to check anyway..... I used to be hardcore into stereos and I had so many fuses blow when I started out it was insane.
Anyway, check it out..... you might also want to ask SA_PYRO_NE who is the moderator for the car stereo 'ICE' section of this board and see if he has any ideas.....
I doubt it has anything to do with your gauge cluster, your car is a 2004. If it's not any of your stereo wires, then take it to the dealership, you have warranty, use it.
Epox 08-10-2004 08:35 PM
Well i tore everything apart its nothing to do with my stereo (stock HU wired to an amp) The fuse that keeps blowing is #41 it has something to do with the cluster when the car first starts cus it takes about 60 sec for the gauges to read anything. when i first blew the fuse i replaced it and it workest for about 2 min before it went again, but now it goes every time i turn the key. what im woried about is if i take it to the dealership they will say that the instalation of the amp voided my warenty.
downloader 08-10-2004 09:09 PM
take it back to the guy who installed your sound system
www.bluewhippet.net
dudemanzx3 08-10-2004 11:59 PM
Did you unhook your system and try to start it then? If you did and the fuse still blows, I would take out the whole system before I took it in to the dealer. They'll do almost anything to try and blame you for the gripe so they don't lose $.
Epox 08-11-2004 12:07 AM
Thanks for all the help but i fixed it. there was a small nick in the remote wire for my amp that was arcing against the body and blowing the fuse. i fiked it and it works great now.
CKA 08-11-2004 08:36 AM
I had the same problem, I had 2 buy a bunch of fuses from Napa, they were the only one's who had them here, but the problem dissappeared, it was weird.
S2 08-11-2004 10:23 AM
That is what I thought it might be.... glad you figured it out....! [thumb]
