-   General Technical Chat (http://www.focusfanatics.com/forum/forumdisplay.php?f=47)
-   -   Perimeter alarm (http://www.focusfanatics.com/forum/showthread.php?t=195251)
ahmadr 04-09-2009 10:41 PM
Perimeter alarm
Is there a way (reprogramming the GEM, or maybe a plug-in module) to somehow enable the factory perimeter alarm functionality on a late 06 - 07 Focus with OEM remote keyless entry?
I know it was an available option on he cars, and looking at the schematics, the keyless entry, power locks, door sensors, lights, and horn are all controlled by the GEM. Also, the car already has the hood sensor. So, technically, everything necessary for the perimeter alarm is already there.
I have heard for GM cars, it it is as simple as changing a setting accessible to dealers on OBD2...
Any thoughts appreciated
P.S. The alarm available from Ford Accessories is virtually an aftermarket one, and requires tapping in (soldering) to existing wires:
http://www.gemsen.com/Ford/Pdf/
http://www.gemsen.com/Ford/Pdf/2007M...e_10-27-06.pdf
http://www.gemsen.com/Ford/Pdf/2007M...s_10-27-06.pdf
ahmadr 04-17-2009 12:09 AM
Any comments? [:(]
I've looked at the schematics on my alldatadiy subscription, and it shows identical schematics for keyless entry and perimeter alarm. So the GEM is already aware of the status of all doors, and is the receiver for the keyless entry (for arm/disarm OR lock/unlock). It controls the door locks, horn, and lights. Therefore, it already has all the necessary stuff to act as a perimeter alarm...
That's why I have come to believe that maybe it is just a software thing. Any thoughts?
Does anyone know how (with what) can the GEM settings be changed? Or better yet, does someone have the list of options it has?
Here is an example from GM (Dodge)
http://www.srtforums.com/forums/f10/...n-story-44934/
To switch operating modes or to configure a new module, a DRB III scan tool must be used.
(1) Hook up the DRB III scan tool to the Data Link Connector (DLC).
(2) With the key in the ignition, turn the key to the RUN position.
(3) After the DRB III scan tool initialization, perform the following:
(a) Select "Theft Alarm."
(b) Select "VTSS."
(c) Select "Miscellaneous."
(4) Once in the "Miscellaneous" screen:
(a) If you wish to configure a new module, select "Configure Module."
(b) If you wish to put the module into customer usage mode,
select "Enable VTSS."
(c) If you wish to put the module into dealer lot mode, select "Dealer Lot."
