-   General Technical Chat (http://www.focusfanatics.com/forum/forumdisplay.php?f=47)
-   -   Clutch Pedal Spring (http://www.focusfanatics.com/forum/showthread.php?t=149194)
19TbirdSC91 02-09-2008 01:14 PM
Clutch Pedal Spring
If this is a repost, i apologize, i searched around and can't find the answer anywhere. A spring went flying off my clutch pedal one day when i pushed it in, i went and got a new one from ford, but i cant tell where it came from. Thanks for your help.
Sean McConaha
FocusVet 02-09-2008 01:36 PM
Here ya go, http://www.focusfanatics.com/forum/s...ad.php?t=87050 hope this helps, but I'm still looking for the proper place to hook in the lower mounting point.
FocusVet 02-09-2008 07:24 PM
biddy bumpy
RhodySVT 02-09-2008 08:10 PM
yeah had that happen to me too mine was from the neutral safety switch. Pita but a little
superglue fixed me up
ATXSVT 02-10-2008 03:37 PM
Might sound like a newb q's but will that cause the car not to start? I believe I'm in the same situation.
Last night I went to my mom's job to bring her some food. No problems with the car. 20 mins later when I'm ready to leave the car won't start. When I turn the key, no turn over, no sound no nada. The light dash is on and the radio comes on. So I had to leave it there for a few hours. When I come back and was about to pull the hood latch, I look down and see a spring and 2 wires (red/black connected to a plastic piece) hanging on my clutch pedal. Going over the thread and seeing the similarities I'm wondering if this is the problem.
-Alie
19TbirdSC91 02-10-2008 05:11 PM
Spring wouldn't cause that problem, BUT the connectors probably could...makes sense to me.
Sean
ATXSVT 02-10-2008 06:11 PM
Found the problem, broken Clutch Safety Switch.
FocusVet 02-10-2008 08:47 PM
That would do it! Glad you found the problem [thumb]. Could you are anyone look at you clutch return spring and let me know when it hooks at the lower point(behind the clutch master cylinder). Thanks a bund!
Sypher 12-22-2008 03:19 PM
Hi all Just had the same thing fail on mine . I couldnt find the lower mount point staight off but I HAVE pics of where it mounts to for those that are interesed .
you can see the master cylinder pipes in the top pic ( this is looking inbetween the pipes to the pedal mounting )
http://img.photobucket.com/albums/v7...8/DSC04254.jpg
http://img.photobucket.com/albums/v7...8/DSC04253.jpg
zoomed in pic ( you can still see the remains of my spring in the pic ) .
The lower mount is a slip of steel with a slot , sticking out 90 degres from the pedal mount plate towards the clutch master cylinder pipes .
Hope this helps you guys out ???
focusowner2 04-22-2009 01:38 PM
Hey
Ive got a 2005 focus estate, and my spring went a couple of days back.
I got a new spring from ford for 4, and then put it in this afternoon.
My lower mounting point looked kinda different to the photos already posted, but im pretty certain that ive got it in the correct position.
I did take some photos to upload to this forum, but I can't see how - it looks like you have to host them elsewhere and link to them?
Anyway, here is my advice...
It's nearly impossible to see the lower mounting point from lying with your back on the floor and your head under the dash. However, moving the steering wheel as far out and up as it will go affords a nice view from under the steering column. I also held my camera phone up under the dashboard with its light on enabling me to "see round corners"...
When fitting the spring, do the lower mounting point first, holding the spring vertically above the mounting point, and hooking in by moving the bottom of the spring towards the front of the car. Once it's hooked in, flop the spring towards the back of the car, and it lands on the pivot of the clutch pedal. Then get a screwdriver, and pull the free end of the spring onto the hook on top of the clutch pedal.
Hope it helps someone...
