Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lean Less: The Inside Scoop on Anit-Roll Bars from GRM
Old 03-19-2006, 02:55 AM   #10
Oni
Oh yeah!
Oni's Avatar
Fan#: 24899
What I Drive: An unloved Focus
Points 5,900, Level 49
Points: 5,900, Level: 49 Points: 5,900, Level: 49 Points: 5,900, Level: 49
Level Up 75% Completed
FF Reputation: 4 Oni Good Standing Member
Buy-Sell-Trade Rating: (6)
Not necessarily. The location of the bolts and mounting points for any aftermarket sway bar should match up to the OE unless fabrication is required. If the H&R sway bar were to have a longer moment arm, all it would simply do is readjust where the bar is located under the car by possibly a few centimeters. Basically, if you can imagine the OE bar is fixed but has some space around it, then the moment arm of the aftermarket sway bar can be lengthened or shortened as it has room to be moved forward and back in the empty space.
formerly known as the member ilcowil
Oni is offline
