Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lean Less: The Inside Scoop on Anit-Roll Bars from GRM
Old 03-09-2006, 09:02 AM   #5
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
Just as an interesting side note, Sway-bars are used by manufacturers in very different ways. BMW for instance, believes in stiffer springs/dampers with relatively weak sway-bars whereas Lotus uses a lot of sway bar with a relatively soft damper/spring setup. Both are great handlers, but shoot for the same goal with different methods.
So many people forget how much of an interconneted system it all is, but of course not many companies would sell (or customers would buy) nothing but a front to back full suspension upgrade... After all, even an upgrade in tires could totally change the TTLD.
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
