Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Is rear toe adjustable with stock suspension?
Old 02-07-2006, 06:21 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
Toe is completely adjustable on the rear...it's the camber that isn't...
Not to confuse the issue, but the adjustment for the toe will change the camber,
but it will barely be measurable.
All the way in (toe out), versus all the way out (toe in) only changed the camber by 1/4.
Check the following pic:
http://www.focusfanatics.com/forum/a...&postid=325467
Those two gold colored eccentric bolts in the center of the lower crossmember are what's used to adjust the toe.
(Shown on either side of the 2X4 on the jack plate)
WD40 Reverend GripShift - FF Moderator
WD40 is offline
