Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - two codes EGR I'm guessing...
Old 01-24-2006, 04:07 PM   #1
SpeedOften's Avatar
Fan#: 2139
What I Drive: E90 335i, 2002 E53 X5 4.4i
FF Reputation: 28 SpeedOften Great Standing Member
Buy-Sell-Trade Rating: (5)
I"m getting these two codes:
P0171 - System to Lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit. For lean and rich DTCs:
P1406 - DPF EGR Sensor Downstream Hose Off or Plugged While driving, the EGR monitor commands the EGR valve closed and checks the differential pressure across the EGR orifice. The test fails when the signal from the DPF EGR sensor continues to indicate EGR flow even after the EGR valve is commanded closed. Downstream hose is disconnected
So the EGR valve isn't working right.. Any ideas on how to fix this?
SpeedOften is offline
