Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT tire size question
Old 01-20-2006, 04:54 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
You should be looking for a tire that is as close to 24.1 inches in diameter as possible.
SVTF stock diameter is 24.6"...
Regardless, 215/50 would be a tad tall at almost 25.5".
I run 205/55/16 (24.9") on 16X7's (45mm offset) in the winter with no problems, but it's very close.
If you're really set on that size, you might have a shop mount one up, and check for issues.
Though, IMHO, that's just too much.
Not only the aforementioned speedometer error,
but you're also going to lose a significant amount of acceleration out of the hole with that tall of a tire.
Here's a good tire size calculator if you want to check some numbers:
http://www.1010tires.com/TireSizeCalculator.asp
And, here's another one for checking different offset wheels:
http://www.1010tires.com/WheelOffsetCalculator.asp
WD40 Reverend GripShift - FF Moderator
WD40 is offline
