Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The proper turn?
Old 12-13-2005, 03:37 AM   #6
FocusInAlaska
FocusInAlaska's Avatar
Fan#: 18038
What I Drive: 2004 Ford Comp. Orange SVT Focus
FF Reputation: 5 FocusInAlaska Good Standing Member
For driving in the twisties being able to down shift as you approach a corner is important. Knowing how many rpm's to pick up when you push the clutch in and move the shifter to a lower gear is key. This is something you can get a feel for by practicing as you approach stops or slow down on exit ramps. Ideally you'll make a quick stab at the throttle, bring your engines up several hundred rpm's. When you quickly let out the clutch and there is no driveline shock you've got it down. You can contiue deaccelerating under engine compression, or be in the right gear for accelerating. I like to corner at around 5k rpm.
04 SVT Focus
"lunch box" muffler delete
15.35 @89mph, 2.29 60', 9.90 1/8 (100% stock)
FocusInAlaska is offline
