My shifter bushing is chewed up. I've searched all over but haven't found the answer I want to hear. Is there any place I can buy a replacement bushing, OEM and or after market?
Welcome to FF man!! This site is very helpful and informative to the SVT Focus owner. There is a tremendous amount of knowledge and know-how here. This group can help just about any owner with just about any problem. Have fun and welcome, again!!Been contacting wreckers, and more than a few SVT dealerships looking for just those parts. Ford here in Canada no longer sell/manufacture the shaft/arm or bushing.
Finding this forum and the above links has saved me from even more headache! Thanks.
Original FJ source Post 15That being said if you want to try and build your own bushings I've posted the specs in the main "Search for a better shift" thread but I'll post them again here. I start with a 3/8 x 3/8 strip of nylon (previously delrin). Cut the strip so you basically have a 3/8 cube. Use a 9/32 drill bit for your hole. File one side down to 9.15mm. The bushings I send out are basically 3/8 (height) x 3/8 (width) x 9.15 mm (width that will fit into the trough) I know I'm jumping between imperial and metric but you get the idea.
How can I find this bushing as well? I put a steeda short throw in my o3 svt and this bushing is all wobbed out like your in the oictureMy shifter bushing is chewed up. I've searched all over but haven't found the answer I want to hear. Is there any place I can buy a replacement bushing, OEM and or after market?
