Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - * * * * C o m p l e t e ' H o w T o ' A r c h i v e * * * *
Old 11-08-2005, 04:36 PM   #3
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
Points 196,150, Level 100
Points: 196,150, Level: 100 Points: 196,150, Level: 100 Points: 196,150, Level: 100
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Interior Modifications and Articles
Electrical Related Modifications including ICE
Adding 12v Power To Your Door Mods by devil_dog_switch
Adding an OEM Tach Cluster on a 2005 Focus
Adding a 4 Channel Amp to a Stock Headunit by jmanpc
Aftermarket Tach on a 2.0L Duratec Installation Instructions
Audiophile Enclosure Upgrade Instructions
Ashtray Switch Panel (for neons, LEDs, etc) by OrangeSVTguy
Blaupunkt MP3 Wiring Diagram
Carputer IR Crossover/Linearization Design by WuNgUnSVT
Colored Odometer and Needles Modification Instructions
Complete Dash Color Change Modification Instructions
Door Chime Mod (Silence)
Door Panel Removal and Speaker Installation by StevenFocus
Door Switch SVT Lighting Instructions by Rudel
Drilling out Ignition Cylinder After Lockup and Replacement
Easy Trunk Lighting Upgrades by devil_dog_switch
FC Gauges with Contour Needles by Superflea
Foam Speaker Baffles in Front Doors by MisterJohnson
Gauge Cluster Removal and/or Reinstallation Instructions – 2005 Focus
Gauge Face Installation Instructions
Glow Gauge (6 Color) Installation Instructions
Hardwiring Radar Detector Instructions
Hatch/Truck Area Lighting Upgrade by SkaAddict
Heated Seat Repair Instructions by SiGuyUWP
Heater Blower Resistor Information
Indiglo Odometer Trick
Instrument Cluster Removal (2005+) by BiggTigger78
LED Vent Lighting Instructions
Light Up Door Handles by devil_dog_switch
Light Up Speakers by devil_dog_switch
Make a MP3 Harness
Make a Speaker Enclosure
Make your own O2 Cheater/MIL eliminator by R3d_RovrZX3
Make your own S2 (Red) Dash Needles
Needle Calibration
Odometer Blue LED (or whatever color) by c.ohamara_86
Oil Pressure Gauge Install Instructions
PATS Light (Red) to (Blue) by OrangeSVTGuy
Power Window and Locks Lights in the Buttons – Hook up Instructions
Radar Detector Wiring Modification Instructions
RS Center Console and Starter Button Installation Instructions
SPAL Power Window Installation Instructions by Roland07
Speaker Wire Colors
SPI Oil Pressure Gauge Installation Instructions
Start Button Installation Instructions
Stock Stereo Removal Instructions
SVT Aftermarket Deck W/Stock Sub Wiring
SVT Heated Seat Switch Fix by OrangeSVTguy
Tach Driver Installation Instructions
Turn Your Driver's Side Vent into a Guage Pod by pistolgripbmx
TripTunes Install by 02SilverSVT
ZX3 Power Window Regulator Install by SVTF4243
2013 Focus, Sony 10" Speaker Sub Mod by Now534
Non-Electrical Modifications
’A’ Pillar Gauge Pod Installation Instructions
A/C Vent 00-04 To Gauge Pod Instructions by volcomstone1966
Aftermarket HVAC Knob Installation Instructions
Aftermarket Pedal Installation Instructions
Alternator Clip How-To
Back Seat Delete Instructions by ..:: sleestak ::..
Center Console & Dash Removal Instructions – 2005 Focus
Cluster Ring Mod by norcalfocus01
Complete Dash Removal Instructions
Custom Door Sill Plate by CJohn364
Cutting ATX Shifter Shaft Down Instructions
Cutting MTX Shifter Shaft Down Instructions
Door Panel Insert Replacement and Recover
Door Sill Installation Instructions
E-brake Handle Installation Instructions
Fiberglass Gauge Pod Making Instructions
Front Door Panel Removal Instructions
Gear Shifter Surround Installation Instructions
Glove Box Removal Instructions
Gear Concepts Pedal Installation Instructions
Headliner Removal Instructions
Headliner Removal & Painting Guide by dorfeater
Interior Panel Removal (2006 ST) by edgofrea1ity
Lowering The Armrest by NA_Built
Manual Window Crank Handle Removal and/or Reinstallation Instructions
Painting Interior Trim – Prepping Instructions
Painting Interior Trim – Painting Instructions
Painting Interior Trim by maul
Passenger Dash Panel Removal (08-09) by 08xcel
Rear Quarter Interior Trim Removal Instructions
Rear Seat Cargo Mode Instructions
Removing 2008 Ford Focus Stock Radio
Removing and/or Reinstalling the 'Oh S**t Handles'
Removing Glued Instrument Cover and Custom (Metal) Gauge Bezel Installation Instructions
Repair Broken Plastic Tabs (Speaker Grill) by MisterJohnson
Reverse Lockout Removal Instructions by cruzstyle
Shifter Boot Installation and/or Removal Instructions
Shift Knob and Boot on ATX Instructions
Show Your Audiophile Who's Boss/CD Error
Spedometer Bezel Dual Gauge Setup by redsleeper
Stereo HU Bezel Removal Instructions 2000-2004
SVT Dead Pedal Install (Redlinetuning) Installation Instructions
SVT Ebrake Install Instructions by CheckMyVitals
Swap in Tilt Steering Column/Replace Clockspring
Turn Signal Silencing How-To by W~Phoenix~{RC}
Tweeter Mounting for Manual Windows
HOW TO-Make custom inserts for door panels by Davey Boy
How To: Change SVT Gauge Color by mtothaj
Chad (S2)
S2 is offline
