Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - * * * * C o m p l e t e ' H o w T o ' A r c h i v e * * * *
Old 11-08-2005, 04:34 PM   #1
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
Points 196,150, Level 100
Points: 196,150, Level: 100 Points: 196,150, Level: 100 Points: 196,150, Level: 100
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Exclamation * * * * C o m p l e t e ' H o w T o ' A r c h i v e * * * *
The following links will direct you (some external links, some on FocusFanatics) to the various HOW TO’s that I have found pertaining to modding, maintenance and replace/repair of parts on the common focus. My goal is to have a complete list of every ‘how to’ out there for the focus. I have yet to see on ANY focus site a very extensive list of ‘how to’ articles until now.
Please read over the note below……
Warning: Neither Focus Fanatics nor its Members may be held responsible for the outcome of performing such a modification to ones car. Such acts are performed at ones own risk, and sole responsibility must be assumed. This may include, but not limited to, the voiding of the vehicles factory warranty.
Note: The HOW TO LINKS to the teamfocus website are somewhat back up, via an 'archived' link. When you click these HOW TO's, you have to HIGHLIGHT the entire page to be able to 'view the text' otherwise it will look like a blank webpage.
Engine Components and Performance Articles
Air Intakes
AEM Cold Air Intake Installation Instructions
AEM Short Ram Intake Installation Instructions
AEM SVT Cold Air Intake Installation Instructions
Airbox Resonator Removal Instructions
BlazingCopper_ZX3's Stealth Cold Air Intake for the 2005 and up Focus
Iceman Intake Installation Instructions
K&N Drop in Filter Replacement Instructions
MAC Short Ram Intake Installation Instructions
Making an Iceman ‘Clone’ Intake
Making a Heat Shield for Short Ram Intakes
Replacing Stock Air Filter Instructions
Stealth CAI (Duratec) by jhurst747
SVT Snorkle Installation Instructions
Volant and SVT Snorkle Installation Instructions
Engine and Powertrain Components
AEM Cam Gear Installation Instructions
Accessory Drive Belt Replacement Instruction (SPI)
Accessory Drive Belt Replacement Instructions (Zetec)
Adjusting Shift Cables (MTX75 Trans) Instructions
Aftermarket Cat Back System Installation Instructions
Aftermarket Plug Wire Installation Instructions
Alternator Clip How To by SVTFucus
Amsoil Dual Remote Bypass Filter Installation Instructions
ATX Removal and/or Replacement Instructions
ATX Remove & Replace with Pics by illinipo
B&M Short Throw Shifter Installation Instructions
Brad's Fan Modification Instructions by W~Phoenix~{RC}
Broken DSI Clip Fix Instructions by sleestak
Camshaft Installation and/or Removal Instructions
Clutch Master Cylinder Replacement by pokeySVT
Coolant Leak / 'O' Ring Replacement Instructions by bryanjw82
DIABLO Chip Installation Instructions
DPFE Service and Repair Instructions
Dyno-mite High Output Coil on Plug Install by auzzie
FocusCentral 65mm Trottle Body Installation Instructions
FocusSport Under Drive Pulley Installation Instructions
FocusSport Driver’s Side Engine Mount Installation Instructions
Fuel Filter Replacement Instructions
Fuel Pump Replacement by ..:: sleestak ::..
Fuel Rail and/or Injector Removal / Replacement Instructions
Gas Pedal Cable Replacement Instructions
General AC Troubleshooting and Repair by whynotthinkwhynot
Improving Chasis Ground Point Instructions
Ingalls Engineering 'Stiffy' Installation by 03OrangeSVT
Intake Manifold / Replace IAC Valve Removal and/or Reinstallation Instructions
Intake Manifold Removal and PCV - Duratec by blueoval23
JBA Shorty Header Installation Instructions
Kenne Bell Boost-A-Pump Installation by focusguy87
Lunchbox Removal Instructions by BradWhite
Mechanical CEL Fix for a Header by SYZ
PCV House Changing Instructions by trailbikerider
Replace ECT Sensor by FormerSpeeder
Replacing the Thermostat and Housing Instructions
Screaming Demon Coil and Live Wires Installation Instructions
SCT Chip Installation Instructions - Page 1
SCT Chip Installation Instructions - Page 2
Setting DOHC Timing by ztecpower
Solutions for the 65mm TB 'Sticking' Problem by S2
Spark Plug Wire Loom (ZipStrap) Trick by b16sir1991
6 Speed Swap Information by CDSilver5DoorSVT
SPI Accel Coil Pack Upgrade Installation Instructions
SPI Screaming Demon Coil and Livewire Installation Instructions by waterboy
SPI Shorty Header Installation Instructions
SPI Throttle Body Swap with Modified Mustang Throttle Body Installation Instructions
SPI Timing Belt Replacement by untenops
Starter Removal and/or Replacement Instructions
SVT Timing Belt Replacement How-To_Ford Manual
SVT CFM DSI Billet Clip Install by SVTF200487
SVT Getrag Transmission Flush by BlackJack03
SVT Header Install by lildisco
SVT IMRC DSI Intake Manifold Upgrade for 'Zetec' Engines by focituner
SVT LSD Differential Install by scrammer
SVT Ram Air Duct with Pipercross Style by c9ollie
SVT Short Shifer Installation Instructions by WD40
SVT Traction Control Kill Switch Installation Instructions
Transmission, Common Problems and Solutions by aokrongly
Valve Cover Gasket and VCT Solenoid Replacement Instructions by JohnMichael
VF Engineering Rear Mount Installation Instructions by WD40
VF Engineering P/S Mount by honhon
Water Pump Replacement Instructions by Rabbitccc
Zetec Alternator Removal and/or Replacement Instructions
Zetec Engine Removal and/or Reinstallation Instructions
Zetec Oil Pan Removal and/or Reinstallation Instructions
Zetec Stock Throttle Body Porting Instructions
Zetec Timing Belt Replacement Instructions by lhc_focus
Zetec Water Pump Removal Instructions by grimple1
Zetec Windage Tray and Oil Pickup Installation Instructions
Zetec IAC Cleaning
Chad (S2)
S2 is offline
