Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Performance Engine Roll Back To Factory Setting's
Old 10-29-2005, 12:06 AM   #6
Yel900rr
Fan#: 2792
Points 2,050, Level 27
Points: 2,050, Level: 27 Points: 2,050, Level: 27 Points: 2,050, Level: 27
Level Up 34% Completed
FF Reputation: 15 Yel900rr Great Standing Member
Buy-Sell-Trade Rating: (5)
I don't have a problem with this. This car needed alot I mean ALOT more work than what performance mods were installed. Ordering factory parts in to replace the multiple broken pieces on this car took time and added up. Roc you should be mad at the peolple that butchered your car before we worked on it. Broken bleeders on the brakes so we couldn't bleed the brakes that had a ton of air in the lines, clips not in rear brake line and lines were rubbing metal to metal, front stainless brake lines rubbing the tires, trans pan leaking, stripped lugs, had coilovers on and we needed to get spring seats for the front struts. We installed Apex 1.5 drop springs the car had 225 45 17tires with the wrong offset wheels so the rear tires rub.
If we knew what we were getting into when you made the appointment things would have went faster and we are swamped in the shop and on the dyno. So we can't push other appointments back to take care of another car that we weren't totally prepared for.
You car ran great when it left and made the power we figured it would.
Yel900rr is offline
