Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear SVT sway bar on 2002 SE - HELP
Old 10-11-2005, 05:16 PM   #4
bigal
Fan#: 21961
What I Drive: 2005 CD Silver ZX3
Points 403, Level 8
Points: 403, Level: 8 Points: 403, Level: 8 Points: 403, Level: 8
Level Up 6% Completed
FF Reputation: 1 bigal Good Standing Member
Nothing is really fabricated just basically cut. You just take a 2.75 muffler clamp end and have someone plasma cut it .The best way is to make a template out of cardboard or similar material cut it to the shape of the muffler clamp. Then take the template and keep cutting and shaping till it fits snugly to the crossmember.Once you are satisfied that it is correct lay the muffler clamp on the template and trace the shape of your final measurements. Take it to someone that has a plasma cutter or something similar that can cut the shape and thats it.
The flat pieces I cut by hand but like I said it would be neater if a machine shop cut them.
Once it is cut the install time is probably 30min.
bigal is offline
