Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - $200 steeda short ram,custom short ram...priceless!
Old 08-17-2005, 09:07 AM   #22
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
Originally posted by ZXRR
no check engine light,the maf flow sensor can only go in one direction,so to make this work i had to flip the sensor around inside the intake so it was facing the same direction as it did on the factory setup,only problem was is that the holes on the sensor for the bolts dont line up,so i had to file down some plastic on the sensor,and enlarge the holes to make it work took a little bit of time but works great now.
Did you check for air leaks after enlarging the MAF hole/modification?
Air leaks are not good.
Just reading.....
microtonal is offline
