Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Rear wiper problem; motor or relay?
Old 08-11-2005, 08:17 PM   #2
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Sound like the motor. Likely the bearing or bushings are frozen from corrosion. They generally as considere "non-repairable," however, I have, in the past, had some success using WD-40 and hand twisting to fee-up the shaft/beaing/bushings, and then using sone motorcycle chain lube, or similar penetrating=then=thickening lubricant.
Good luck, but if it was hot to the touch, it doesn't sound like a relay.
penguin is offline
