Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Custom "Rear Dome Light"
Old 05-16-2014, 12:49 PM   #24
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,931, Level 44
Points: 4,931, Level: 44 Points: 4,931, Level: 44 Points: 4,931, Level: 44
Level Up 91% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by t2fuller View Post
Looks great! Nice to see the dimming works. Which LED strip did you order? I am thinking of doing the exact same thing and I want to be sure I get a good quality light. I am assuming you spliced off of the wires pictured previously, in the A pillar and ran above (or around) the headliner as discussed, and mounted the light to the black edge on the rear glass. I like this because there is no need to remove or cut up the headliner to get away with this. Thanks for the discussion!
I ordered 39" of this guy:
http://www.superbrightleds.com/morei...ht-strip/1466/
The splices and routing you mentioned are correct, that's exactly how I did it.
If you can't wear it out, burn it off
DarderSauce is offline
