Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT brake swap
Thread: SVT brake swap
Old 07-09-2005, 10:57 AM   #1
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 244,429, Level 100
Points: 244,429, Level: 100 Points: 244,429, Level: 100 Points: 244,429, Level: 100
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
SVT brake swap
stock front disc with 17" wheel
SVT front disc with same wheel
Rear with the stock set-up all removed
Rear arm dangling before we took it off to compare to SVT set-up... They are different on the wagon due to the shock mount... YOU DO NOT have to remove this to do the swap. You can just swap the spindles. Or on a zx3 zx5 you can change out the whole arm assembly. To Change the spindles it is 4 bolts and you have to grind the heads off of two rivets in the middle
The arm with the spindle just removed.
Here you can see where I ground off the rivets
This is where the front hook-up is for the ebrake cables...This is with the heat shields removed
New SVT stuff on! Sexxy
Stock front disc and SVT disc
Again!
Front SVT spindle and my awesome KW suspension ( really like it)
Stock junk!
Front spindle missing.
SVT set-up bolted on!
If pics don't show, just go here!
http://smg.photobucket.com/albums/v8...0brake%20swap/
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
