Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Timing Belt Info
Old 12-30-2003, 06:59 PM   #2
Spanky6935
Spanky6935's Avatar
Fan#: 2327
What I Drive: '00 Green Zx3
FF Reputation: 1 Spanky6935 Good Standing Member
TORQUE SPECIFICATIONS Application Ft. Lbs. (N.m)
Camshaft Sprocket Bolt (Except Focus) Intake ......................................................50 (6
Exhaust Step 1 ....................................................................... 44 (60)
Step 2 ..................................................................... 88 (120)
Camshaft Sprocket Bolt (Focus) Intake & Exhaust ......................................................... 50 (6
Catalytic Converter (Escort) Bracket Bolts ..................................................... 41-47 (55-64)
To-Exhaust Manifold Bolts ................................. 41-47 (55-64)
To-Muffler Pipe Flange Bolts ............................. 34-39 (46-54)
Crankshaft Pulley Bolt .................................. 81-89 (110-121)
Crossmember Bolts (Escort) ............................ 69-93 (94-126)
TORQUE SPECIFICATIONS (Cont.) Application Ft. Lbs. (N.m)
Engine Front Support Insulator Bolt/Nut (Except Focus) ..............................61 (83)
Engine Front Support (Focus) To-Engine Bracket Nut ................................................ 59 (80)
To-Frame Bolts ............................................................ 42 (4
Engine Lower Support Insulators (Contour, Cougar & Mystique) Right-Hand Auto. Trans. ............................................................. 88 (120)
Man. Trans. ............................................................... 42 (4
Left-Hand All Vehicles ...........................................................88 (120)
Exhaust Camshaft Center Plug ..................................... 27 (37)
Serpentine Drive Belt Idler Pulley Bolt ............................ 35 (40)
Spark Plugs ................................................................... 11 (15)
Timing Belt Tensioner Attaching Bolt ............................ 18 (25)
Water Pump Bolt ........................................................ 13 (1
Water Pump Pulley Bolt ................................................. 17 (24)
Wheel Lug Nut Escort (Alloy Wheel) ............................74-100(100-135)
Escort (Steel Wheel) ..............................66-87(89-117)
Except Escort ..................................................94 (128)INCH Lbs.(N.m)
Center Timing Belt Cover Bolt .............................. 53-71 (6-
Lower Timing Belt Cover Bolt ....................................... 62 (7)
Upper Timing Belt Cover Bolt Except Escort ............................................................... 89 (10) Escort ............................................................................. 35 (4) Valve Cover ................................................................... 62 (7) Valve Cover Appearance Cover ....................................... 62 (7)
© Copyright 2002 Mitchell Repair Information Company, LLC. All Rights Reserved.
ASE Certified Technician:
Specializing in Ford Focus' and Ford Escorts
If you have questions, we have answers!
Spanky6935 is offline
