Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fusion or Escape 6spd auto a possible replacement for the DCT?
Old 03-29-2014, 04:44 AM   #18
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 1,212, Level 19
Points: 1,212, Level: 19 Points: 1,212, Level: 19 Points: 1,212, Level: 19
Level Up 12% Completed
Level up: 12% Level up: 12% Level up: 12%
FF Reputation: 1 Seminoles Good Standing Member
Originally Posted by bshin352 View Post
do the bellhousing bolts even line up? let alone tcm being able to work with the ecu?
these new cars are nothing like the old ones where you could swap a manual in place of an automatic.
You could put a focus manual in place of the automatic same as the old days just seal up the transmission control module plug from water entering it you might get a check engine light but could be turned off from a tuning point sense Ford would not turn off the automatic transmission inputs on the ECU they wont even fix there car (it's normal) if i only had money for every time I heard that I would have an ST...LOL
Seminoles is offline
