Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - New owner problems - windows
Old 03-21-2014, 02:35 PM   #10
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 12,288, Level 72
Points: 12,288, Level: 72 Points: 12,288, Level: 72 Points: 12,288, Level: 72
Level Up 60% Completed
FF Reputation: 9 SilverPony2001 Good Standing Member
Originally Posted by Krayz_tom View Post
Thanks for the guys!
Is there anyway I can swap the window modules to make mine go up and down with one touch?
I'm not sure if that's even possible. The cars with door modules, the switches and the module itself are controlled by the BCM. The switches only have 3 wires, power, ground and a data wire. You would probably have to re-wire a bunch of stuff, then have the BCM programmed to tell it you now have door modules.
The cheapest/easiest way IMO to add one touch UP/DOWN would be to install an Autoloc module, or something similar. I did this to my SE.
See here:
HOW TO: Installing an Autoloc WC1000 for One Touch Up/Down Base and SE
SilverPony2001 is offline
