Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 01 zx3 not going into 5th
Old 02-24-2014, 01:22 PM   #2
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
You can adjust the cables using those orange buttons on them near the transmission end of the cables. I had to do it after my transmission swap on my 02. I forget the exact procedure as to what position the shift lever should be in when you press them, but if you search the forum you should find it. I think you are suppose to hold the lever far left and depress the button on that cable for horizontal movement, and in 4th gear on the other cable. That could be wrong though.
I know its easier if you have 2 people, one inside and one outside. I only had myself so I made use of some bungie straps to hold the shift lever in place.
FoMoCus is offline
