Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - neg post problem
Old 02-24-2014, 07:30 AM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2015 LWB Transit Connect
Points 644, Level 12
Level Up 88% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
The bottom part of the bolt is 'anchor' shaped see the poster above iminhell \_I_/
For now get some pie plate material, 'drill' a hole then cut/shape it so it covers the 'anchor'.
The other possibility is that you have some sort of anti corrosive felt pad around the post-dump it
Anyway now tighten the connection, it should work
If it does then hunt down some thin brass sheet and replace that first piece
REASON:
To eliminate galvanic corrosion of dissimilar metals
Congrats of having a multimeter, SO MANY here think they can just look at stuff and solve electrical problems and start throwing parts at the situation
mikeeshaq is offline
