Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Mtx75 synchros said bye bye
Old 02-17-2014, 12:50 AM   #6
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,597, Level 100
Points: 30,597, Level: 100 Points: 30,597, Level: 100 Points: 30,597, Level: 100
Forum Activity 100%
FF Reputation: 128 sailor Excellent Standing Member sailor Excellent Standing Member
Easy, he admitted to messing up.
Double clutching can reduce wear on the synchro's, if you NEED to do it you're probably dropping to too low a gear. Forcing it in when the speed difference is too great for the synchro's can wear them out. Hopefully the OP didn't damage the gear dogs enough to make it start popping out of gear. Now he needs to double clutch every time into third.
Changing the trans. lube a time or two to get out most of the carnage would be a good idea, at the price of Ford "Honey" for the trans. the lesson will be reinforced enough.
"Rubber Side Down"
S.R. #275
Focus Takeover #003 / Tarbo Fan #003
sailor is online now
