Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Diagnosing P0420 ?
Old 02-16-2014, 10:36 AM   #6
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
you will either need to scope the sensor or find a scan tool that will show you sensor waveform patterns...
WHEN COLD, the pre-cat (B1S1) and post-cat (B1S2) sensor waveforms will be almost exactly the same in both frequency and voltage swings (amplitude is probably the right word for that).
After driving around and getting the cat hot enough to "fire off" the waveforms will change. B1S1 will still be relatively the same as it was cold, but B1S2 will be at a somewhat more steady voltage (NO voltage swings). it won't look anything like the other waveforms.
you can rule out the rear sensor by that method. if the rear is doing something weird compared to the front during cold running, it's likely a sensor fault. If after driving, the waveforms are still fairly similar, the cat is not operating correctly.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
