Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Diagnosing P0420 ?
Old 02-16-2014, 10:22 AM   #5
sykozis
Fan#: 137929
What I Drive: 2005 Ford Focus
Points 236, Level 4
Points: 236, Level: 4 Points: 236, Level: 4 Points: 236, Level: 4
Level Up 72% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 7 sykozis Good Standing Member
If the downstream O2 sensor is still switching, it won't produce an O2 code because the PCM doesn't see a fault in the O2 sensor. Instead, it determines the fault to be with the catalytic converter.
As BC_ZX3 said, if you have the ability to do so, monitor the switching of the upstream and downstream O2 sensors.
If they appear to be switching at a relatively similar rate, it's most likely you have either a faulty catalytic converter or faulty downstream O2 sensor. More often than not, replacing the downstream O2 sensor will fix the issue.
There is a madness to my methods!!
sykozis is offline
