Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Couple of Car Issues
Old 02-15-2014, 06:27 PM   #5
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,378, Level 100
Points: 31,378, Level: 100 Points: 31,378, Level: 100 Points: 31,378, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Originally Posted by NixNox View Post
Not steam, but stReam. I just put my vents on the window and feet, to defrost windshield.
Understood.
What to lubricate?
**Door latches themselves, the part that clamps to the body to hold the door closed.
And I hope that you understand correctly. When i press my key to lock car - when it works, salon light shuts down and my hazard lights flash one time. I don't have frozen locks or doors. It should be something electrical, not mechanical.
**This is a first, easiest, "fix". If latches are "sticky" they may not close completely. Not fully closed, electric switch is not tripped. Does not work right if electronics think the door is open.
**Many longer threads on the electrical switching exist, this was a quick fix for mine when the trunk latch was sticky.
So I shold just check between body and door, for some connector? Or it's somewhere inside the door or body, but I can get to it from the space between car/body, when I open door?
**Wires between body & door, mine has a connector at the body where the wires pass through the door frame. Space between when door is open.
what do you mean pull off the window?
**Window wiring has a tab for wire connection. It is part of the window & can come off easily. If connector is pulled off to check for voltage or ground, care is needed to avoid pulling this off the window. These connections can come loose from the window, another common cause of your problem.
Again, sorry about my english.
Do not worry, we will try to understand.
I edited to ** my responses, they printed in your quote.
"Rubber Side Down"
S.R. #275
Focus Takeover #003 / Tarbo Fan #003
sailor is offline
