Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Salvage engine questions
Old 02-10-2014, 04:16 PM
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 1,028, Level 17
Points: 1,028, Level: 17 Points: 1,028, Level: 17 Points: 1,028, Level: 17
Level Up 28% Completed
Level up: 28% Level up: 28% Level up: 28%
FF Reputation: 3 forddorf Good Standing Member
Their is not enough difference to worry about. If its a newer year you may need to swap injector harness (one has a square plug and one a rectangular plug going to the ecu depending on the year). Also make sure it has the proper cps before you install it ( the manual trans. takes different sensor then an auto trans.) The newer year cruise cable has a different end on it then the 2000 and 200l years (you can swap your throttle body over or change the cable to the new style)
forddorf is offline
