Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 SVT Seat Swap (Part 2) -- sucked!
Old 05-10-2005, 07:25 AM   #1
snobrdrdans_sedan
Fan#: 20671
What I Drive: 2010 VW GTI
FF Reputation: 1 snobrdrdans_sedan Good Standing Member
Buy-Sell-Trade Rating: (9)
Well...
So I got around to putting in the SVT front seats yesterday, Monday.
Driver side went in fine without any problem and the wiring was good too.
Now the passenger seat is a TOTALLY different story. Some of you are gonna be like...yeah whatever he just doesn't know what he's doing. Well...I do.
Here we go...on the 2005's there is a light on the dash (underneath the Hazard switch) that says "Passenger airbag off"
What happens is if it senses a small amount of weight on the seat, but not enough for a person it shuts the passenger airbag off (& the light on the dash comes on)....kind of like if you had a car seat on the passenger seat or something (to protect the kid obviously). But if nothing is on the seat, then then the airbag works like normal. Same with someone sitting there...it works normal.
So anyways...I get the SVT seat in and do the wiring...I see that there is an extra connection on the stock harness. Go to plug it in and the airbag light on the cluster comes on. I undid the battery and reconnected it and it still back on. So I didn't wanna take an easy way out.
Basically, I had to swap over the sensor for the passenger seat onto the SVT seat along with the stock '05 harness/wiring. This is the part that sucked. Underneath the foam of the '05 passenger seat is a gel like pad with tubing and that tubing goes to a sensor & a little black box which is also wired to the seatbelt. So I had to take that off the stock seat and transfer that to the SVT seat along with the wiring & the seatbelt harness for it. So the stock seat harness is on the SVT seat now & I didn't even need the SVT seat harness at all and just zip tied it underneath the seat.
The gel pad has to go underneath the SVT seat's foam SO I peeled back the cover and put it under the foam. The gel pad did fit perfect and had four push pins that went right in on the SVT seat pan. So it was the same seat pan for '05.
Just that the SVT seat didn't have all the little holes underneath to mount the black box & push pins, so I did a quick stencil of the '05 seat and then drilled the holes the in the SVT seat to make it work/match up.
Just a little time consuming and had to take the bottom part of the seats apart to get it to work right.
Turned out good and everything works fine now. No airbag light on the cluster and it works properly.
I guess I was just the guinea pig...lol.
I should've taken more pics when I was doing the swap, but I was in a hurry & this is what I got...so here are some pics:
Light on '05 dash:
Gel pad underneath stock foam:
Gel Pad off seat:
SVT seat finished:
Picture of what everything is:
Seats Installed:
New Addition (Dead Pedal):
2011 VW CC
Gone, but not forgotten: 2005 ZX3 SES, 2003 SVT ZX5, 2000 SE
snobrdrdans_sedan is offline
