Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Screamin' Deamon coil and Livewires
Old 05-05-2005, 10:41 PM   #2
waterboy
Guest
Fan#: 2258
What I Drive: 2k SPI-T, with Lentech automatic stuff on it
FF Reputation: 1 waterboy Good Standing Member
Buy-Sell-Trade Rating: (4)
Wires installed. They are numbered and have a nice protective boot. You will also need to regap your plugs to .065". A usefull tip is to put a drop of oil onto the threads of the spark plug. Since the plugs and head are differing metals, they are more likely to fuse together over time. When this happens, you can break off the plug in the head or strip out the plug threads. Either way, it's bad news. The oil will make removing the plugs later easier, and will cut down on the oxidation that fuses the parts together. When you are gapping your plugs, especially if you are running Platinum plugs....DO NOT PRY BETWEN THE ELECTRODE AND THE TIP!! You will damage the platinum tip!
waterboy is offline
